General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
how do you...
Old Nov 22, 2006 | 07:32 PM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
Default how do you...
how do you clean the EGR valve? ive heard people talkin bout doin this what does it help with or excatly what is a EGR valve?
Old Nov 22, 2006 | 07:55 PM
Default RE: how do you...
There's plenty of posts you could read through describing the EGR valve and how to clean it, but alas...
EGR valve == Exhaust Gas Recirculation valve
Your's is located on the front of the engine, center of fan, pointing at you. It is about the size of a soda can and has an electrical connection on the top.
If you clean it, you'll need a new gasket for it.
To clean it, use some sensor safe carbon cleaner and an old tooth brush to clean out the passages. Simple as that.
Old Nov 22, 2006 | 10:25 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
What would he gain from cleaning it?
Old Nov 22, 2006 | 11:57 PM
mudsliner's Avatar
alright is there really a point in cleaning it? does to help it run better or what?
Old Nov 23, 2006 | 06:59 AM
If you are having trouble with your idle (fluctuations) or have some missing/stumbling symptoms then yes. If it's running normally, it couldn't hurt, but probably won't give you anything but peace-of-mind.
BDS_237
Apr 19, 2010 11:05 PM
mxboy96
Headers, Intake, & Exhaust
Jan 11, 2010 06:11 PM
fatalshot
Dec 24, 2009 11:59 PM
95_4door
Nov 14, 2008 07:55 PM
kornphlake
17
Oct 10, 2008 01:20 PM
