General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
IAC valve
Old Aug 18, 2006 | 04:13 PM
Mbastet99's Avatar
Mbastet99 is an unknown quantity at this point
Default IAC valve
OK, so I'm still trying to figure out the mystery behind my bad idle, which is now getting worse to the point of dying if I have to sit in traffic too long. Am wondering about the IAC valve, since I was told to check and see what happens when I turn on the A/C....sure enough, the idle does not compensate and dies. Blazer runs great when driving, it's just the idle that is driving me crazy. Is it worth getting it replaced to see if that is the problem? Or are there any other ways to check and see before taking it to my mechanic if that is the culprit? Can't find any vacuum leaks, and have checked it MANY times. No codes or trouble lights so I have nothing to go on....Thanks!
Old Aug 18, 2006 | 06:02 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Default RE: IAC valve
If I remember correctly from one of my other chevys.. that IAC valve is NOT expensive and if its never been changed then it might just be your culpret! I would change it out.. .see if it helps. you can always return it if not. and i've change one, was easy enough.
Old Aug 18, 2006 | 08:29 PM
Mbastet99's Avatar
It's about $60 at AZ, but that's far cheaper than most of the other things that I've tried replacing! Think I'll give that a try unless anyone has a better suggestion...Thanks Dory![sm=thanx.gif]
Old Aug 18, 2006 | 11:11 PM
You should try pulling the TB apart and cleaning everything first. At most, you may need a new tb gasket at that point. If you still have an idle problem after that, then possibly replace the IAC valve.
Old Aug 19, 2006 | 01:21 PM
Mbastet99's Avatar
Thanks for the info. If it ever decides to NOT rain on the weekend I could work on this!!
Old Aug 25, 2006 | 09:31 PM
Mbastet99's Avatar
Thanks for all the help....replaced the air filter, PCV valve, and took off the IAC and cleaned it good (it was coated with carbon) and now the Blazer runs MUCH better!! Glad you guys are here to help us non-car people out....[sm=bounceybounce.gif]
Old Aug 25, 2006 | 09:55 PM
Hey not a problem! Glad we could be here for you!!!
JHZR2
May 24, 2012 04:15 PM
ff_malone
Jan 3, 2010 05:58 PM
bbell
Jun 9, 2009 07:58 PM
ron36535
Aug 13, 2008 12:31 PM
ron36535
Jan 23, 2006 12:06 AM
