General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
rear defroster
Old Jun 6, 2006 | 04:51 PM
okmomw/blazer's Avatar
okmomw/blazer is an unknown quantity at this point
Default rear defroster
One of the spiral wires that hook to the rear window to heat the defroster has come off. What do I use to get it to stick back on yet let the defroster work?????
Old Jun 6, 2006 | 04:54 PM
Default RE: rear defroster
Did the whole spade terminal break loose from the glass? If so, then you may have to solder it back on to make contact again...
Old Jun 6, 2006 | 05:23 PM
Yes, the whole thing came loose. I know this may be a stupid question but you can solder on glass???[8D]
Old Jun 6, 2006 | 06:20 PM
No, you will have to bond it using an epoxy (after roughing up the glass with some sand paper in that area), then solder the joints that lead to the heating elements.
I'll have a look at mine to see how it may be done other than what is listed.
Old Jun 6, 2006 | 09:42 PM
tom1337's Avatar
tom1337 is an unknown quantity at this point
I had this same problem, the dealership said it had to actually soldered and gave me the instructions and part numbers. However all I needed was the solder past kit, just don't sand too hard. Here is a link to a good suplier for the material you need Frost Fighter
blazergirl96
Jan 13, 2010 09:49 AM
gserve
Dec 6, 2009 08:33 PM
ClueMeIn1989
May 26, 2009 08:09 AM
FlatTopFoley
Feb 10, 2009 08:21 AM
Jerry60k
Dec 20, 2008 05:23 PM
