General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
rear end loose
Old Oct 11, 2006 | 10:55 PM
dogz46's Avatar
dogz46 is an unknown quantity at this point
Default rear end loose
hey gang. i noticed the other day that i can pull my back axle of my 84 full size k15 in and out about a quarter inch. not side to side or up and down strait in and out, what the heck. any idea,s. thanks.
Old Oct 11, 2006 | 11:09 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Default RE: rear end loose
Im not sure if you have c-clips or not, I think you do and I think that might be your problem, same crap in my camino, popped the cover and c clip was split.
Old Oct 12, 2006 | 01:00 AM
Chevy Lover's Avatar
Good suggestion by DetroitMuscle. Pull the cover off and check inside for wear or a broken "C" clip.
Do you have any bearing noise from the diff?
Either there is a problem with the "C" clip, or the groove in the axle is worn and wider than normal, or the pinion shaft is worn.
There is always some end play in the axle, but 1/4" sounds excessive....that's 1/4" on the end of the axle with the wheel off, right?
I'm too tired to go out and check mine right now, but I can do it on the weekend if you can wait.....pm me if you want me to check mine on the weekend'cause I'm old and forgetfull
brino1
Feb 25, 2011 08:05 PM
ussexplorer
Apr 11, 2010 06:53 PM
jdpilot
Feb 24, 2008 09:57 PM
pilgrim
Suspension Tech
Feb 14, 2007 02:24 AM
tammikm
Oct 6, 2005 09:59 AM
