General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Replacing evaporator
Old Jun 29, 2006 | 12:11 PM
okmomw/blazer's Avatar
okmomw/blazer is an unknown quantity at this point
Default Replacing evaporator
How do you get the evaporator out of a 2000 Blazer 4X4? I need to change mine and it is a booger to get to.
Old Jun 29, 2006 | 12:17 PM
Default RE: Replacing evaporator
[ol][*]Remove the fan shroud.[*]Remove the radiator.[*]Recover the refrigerant from the system.[*]Remove the compressor discharge hose assembly from the condenser.[*]Remove the evaporator tube from the condenser.[*]Remove the insulator retainer bolts and the upper insulator retainers.[*]Remove the condenser by pulling out on the top.
[/ol]
Now, that's what the book states, but I do not know if it is necessary to remove the radiator.
Old Jun 29, 2006 | 12:47 PM
The evaporator is at the back of the engine not by the radiator at all. I have read some places where you have to take the dash off to get to it. It is covered in a box with a lot of screws that are hard to get to.
Old Jun 29, 2006 | 12:56 PM
Woops. Yeah, my mistake. Clicked on the condenser section and didn't even realize it...
Let me see...
Evaporator Removal:
[ol][*]Disconnect the underhood lamp electrical connector, if equipped.[*]Remove the hood.[*]Remove the PCM.[*]Remove the coolant recovery tank.[*]Disconnect the electrical connectors from the grille mounted lamps if equipped.[*]Remove the right front headlamp assembly.[*]Remove the front bumper.[*]Remove the right wheelhouse panel.[*]Disconnect the radio antenna cable.[*]Disconnect the electrical connector for the horn.[*]Remove the right fender.[*]Remove the blower motor resistor.[*]Remove the accumulator.[*]Remove the evaporator tube.[*]Remove the evaporator and blower module heat shield mounting screws (Utility).[*]Remove the evaporator and blower module heat shield (Utility). IMPORTANT: Retain the evaporator and blower module heat shield mounting bracket for installation (Utility).[*]Remove the evaporator and blower module mounting bolts and nuts.[*]Remove the evaporator and blower module from the vehicle.[*]Remove the six evaporator case section to the blower case section retaining screws.[*]Separate the evaporator case section from the blower case section.[*]Remove the evaporator core from the blower case section.[*]Inspect the seals and replace as necessary.
[/ol]
So that's the proceedure from the book. Now, I don't know if it is absolutely necessary to remove the fender, but it very well may be. I'll let someone that has done it comment on this...
*EDIT* - Ha! What do you know... 2500 posts!
Eric D
40
Aug 12, 2020 05:04 PM
fondo
Aug 8, 2010 06:16 PM
mattj3773
Apr 20, 2010 09:25 AM
steveblazer
Jun 10, 2009 06:55 PM
JediKnight2
Apr 4, 2008 12:44 PM
