General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Sponsored by:
Sponsored by:
Thermometer
Old 08-02-2006, 04:46 PM
GasCan's Avatar
GasCan is an unknown quantity at this point
Default Thermometer
The thermometer on my 2001 S10 Blazer either needs to be recalibrated or replaced because of erroneous readings (Read 49 degrees yesterday when I know it was in the high 90's). Any suggestions on how I can fix this?
Thanks
Old 08-02-2006, 08:18 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: Thermometer
USUALLY this is caused by a sensor with the wrong resistance value (faulty sensor). It could be wiring or the Driver's Info Center, but for a few dollars it's worth throwing an AMBIENT AIR TEMPERATURE SENSOR on it to see if it fixes it. The sensor is located in front of the A/C condenser, behind the grille. It is a small black piece of plastic with a 2-wire connector.
Old 08-02-2006, 11:35 PM
Hanr3's Avatar
Is that hookd up to anything else besides the overhead temp? I mean, does it feed into the puter in any way?
Old 08-03-2006, 07:24 PM
lastcoupe's Avatar
No it is not connected in any way to the PCM. However if you have Automatic HVAC control there are two of these and the second one is for the HVAC system.
Old 08-04-2006, 12:04 AM
Hanr3's Avatar
How does that work?
What is the automatic a/c system?
Old 08-04-2006, 03:48 AM
Chevy Lover's Avatar
Automatic a/c system
Automatic Operation
Automatic
The automatic HVAC system will warm up/cool down and maintain the interior temperature of the vehicle by controlling the A/C compressor clutch, blower motor, air temperature, mode and recirculation actuators to achieve the desired temperature. For fully automatic operation, both the blower and mode switches must be in the AUTO position. Blower speeds will change automatically based on inputs to the HVAC control module. The HVAC control module will always come back to the last settings after an ignition cycle.
In cold temperatures, the automatic HVAC system will provide heat in the most efficient manner. When the ambient air temperature is below 2°C (35°F) and engine coolant is below 10°C (50°F), the HVAC control mode will go into a purge mode. The HVAC control module will into a 60-second purge to the front defrost outlets. To warm the interior quickly, maximum heat mode is used where the blower is at maximum speed, floor mode, air temperature is in full hot and outside air is being drawn in. The vehicle operator can select the extreme warm setting, but the system will not warm the vehicle any faster. Once the desired temperature is reached, the blower motor, mode, recirculation and temperature will be adjusted automatically by the HVAC control module.
In warm temperatures, the automatic HVAC system will provide A/C in the most efficient manner. To cool the interior quickly, maximum cool mode is used where the blower is maximum speed, air temperature actuator is in full cold and the recirculation actuator is drawing air from inside the vehicle. The vehicle operator can select the extreme cool setting, but the system will not cool the vehicle any faster. Once the desired temperature is reached, the blower motor, mode, recirculation and temperature will be adjusted automatically by the HVAC control module.
Old 08-04-2006, 01:53 PM
GasCan's Avatar
I don't have an automatic A/C system, I have the LS model. How hard would it be to replace the sensor and where would it be?
Thanks everyone for the responses...
Gary
Old 08-04-2006, 03:41 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
in your owners manual there is a section on how to reset it. your talking about the one inside the car, the digital read out. if you cannot find your manual i'll gladly find the page and try to scan it for you. just PM me
Old 08-04-2006, 04:00 PM
GasCan's Avatar
Thanks Dory, I do have my owners manual and I'll look in there. Thank you for offering to scan yours for me though. Have a good weekend and stay cool...
Gary
Old 08-05-2006, 12:50 AM
The temp sensor is behind the grille in front of the rad.
You need to remove the front grille as Lastcoupe described.
[IMG]local://upfiles/2910/88D804A0EBAE441F847C9AA3BB2CD5BC.gif[/IMG]
Quick Reply: Thermometer
