General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
weird problem
Old Apr 7, 2006 | 05:07 PM
Kein_mitleid's Avatar
Kein_mitleid is an unknown quantity at this point
Default weird problem
ok not sure what this might be just trying to get some insight on the matter
when ever i step on the gas hard(like to get through a busy road) the engine revs then goes back down then revs and drops down again. it will accelerate just not too fast. it only affects me in first gear when i am putting the most load on it. any ideas what could cause this?
oh yeah it is a 2000 blazer automatic 4 door
Old Apr 7, 2006 | 06:52 PM
magtec's Avatar
magtec is an unknown quantity at this point
Default RE: weird problem
throttle position sensor, maybe? i'd think it'd happen intermittently through all gears, though.
does it feel like the transmission is slipping?
Old Apr 7, 2006 | 06:56 PM
Hanr3's Avatar
DO you have any stored codes?
Could be a fuel delivery problem. Like partially pluggeed fuel filter.
Old Apr 7, 2006 | 07:01 PM
magtec's Avatar
that's a good point. is the engine revving too high, or is it dropping too low?
Old Apr 7, 2006 | 07:54 PM
i don't think the tranny is slipping, because when it revs i speed up then the rpms drop and i slow down. i would think if it was the tranny it would just rev up. This is the first automatic i have owned it 9 years.
No check engine light i did not even think of putting it on a code reader
I would say the drop is the strange part
I think I need to pick up a manual
Old Apr 8, 2006 | 06:17 PM
ok i am going to change the spark plugs and the fuel filter in hopes.
anyone have advise on the #3 spark plug it is right behind the steering shaft i cant seem to get anthing in there
Old Apr 9, 2006 | 12:58 AM
ok so the spark plugs fixed the problem, but i still can't get to that #3 plug so i have one old plug in there
Old Apr 9, 2006 | 05:44 AM
magtec's Avatar
go through the wheel well to get to plug #3.
Old Apr 9, 2006 | 04:06 PM
blazin97's Avatar
blazin97 is on a distinguished road
you have to go threw the wheel well and turn the steering wheel till the flat part of the shaft is up. Then put the socket on it then extention, etc.
hotrodsbyg
Aug 15, 2011 11:47 AM
gERgMan
Sep 6, 2008 07:27 PM
phil01ss
Jun 30, 2006 04:54 AM
turboxb9s
Jun 20, 2006 09:08 PM
timetoblaze
Jun 2, 2006 01:17 PM
