General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
whistling noise
Old Jun 28, 2006 | 08:05 PM
jimmyjr1313's Avatar
jimmyjr1313 is an unknown quantity at this point
Default whistling noise
just bought a 1999 chevy blazer with 52000 miles. when i start it there is a whistling noise coming from i think under the engine. wondering what it could be. goes away after 30 seconds or so. any help is greatly appreciated.
Old Jun 29, 2006 | 11:18 AM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Default RE: whistling noise
Under? what year, model.... motor? the onlly thing i can think of is what i had on another vehicle. when i would start it up and get a whistle for like a minute... it turned out to be the altinator... the pully on it.
Old Jun 29, 2006 | 11:25 AM
You'll definitely want to check your belts. If you can't remember when the last time your accessory drive belt was changed, just change it and keep the other one for a spare (I carry a spare with me in all of my vehicles - you never know when you could use it!). While/if you have the belt off, rotate the alternator by hand to see if there are any rough spots. As Dory stated, it could be the alternator starting to go (dry bearing) and after it spins for a bit, it may quiet down (for now) because of the heat buildup in the bearing. That won't last though and you should be able to feel some stickyness (is that a word - lol) in the alternator when rotated by hand.
Now another explaination is the positioning of the IAC valve and how it is used to control the idle speed of your truck. The IAC (idle air control) valve is located in the throttle body. It is a simple pintle valve arrangement and on certain vehicles, it can cause a whistling sound on cold startups if the passage gets dirty. If this is what it turns out to be, a simple cleaning of the throttle body (requires removal of the TB), may correct the annoyance.
Good Luck!
Old Jul 2, 2006 | 02:52 PM
thanks i will check on those things today
Klturi421
May 16, 2011 03:46 PM
masterchf117
Apr 20, 2011 06:36 PM
racsan
Jan 28, 2011 04:24 PM
bdubs
Jul 26, 2009 04:41 PM
jdpilot
Jun 12, 2009 09:14 PM
