carburetor, intake, headers....
hey guys, i have an 84 blazer, and its totally smogged up right now. i just bought headers (non-egr), edelbrock performer intake (non-egr), and an edelbrock 600cfm(non-egr). when i pulled off my air cleaner, it was like vacuum hose city down there and im really not sure what is considered smog (whichi willbe removing), or what i need to keep for my intake manifold and carburetor. i did locate the manifold vac line and distributor vac line but it said i needed to hook up the transmission modulator line to the drivers side vacuum port on the carb. so if anyone knows about this if you could tell me or send me a picture, it would really help me out. also, i noticed that there is this little black and redsquare rectangularbox ( like 1 inch by 2 inches thats on a bracketwith some electrical wires hooked up to it and two vacuum lines that connect to other vacuum lines that connect to others..) and i wasnt sure if ishould remove this or not after i put everything on.my truck is registered in yavapai county in northern az somy truck does not need smog equipment.thank you
Follow the vacuum line from the transmission up onto the intake for the transmission vacuum modulator. The only other things that I can think of would be the vacuum source for the 4wd if so equipped and the source for the HVAC system which goes through the firewall (may be the same source).
grimreper912003
Headers, Intake, & Exhaust
Oct 23, 2010 07:48 AM
scott_wheels
Apr 25, 2010 02:37 PM
