Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
cold air intake during winter=bad idea?
Old Nov 2, 2012 | 12:48 PM
50lb_cat's Avatar
Default cold air intake during winter=bad idea?
I just put my CAI on at the end of last winter. Now I'm hearing that I should remove it during winter months because the air is so cold and dense the computer will dump excess fuel so it won't run lean. Also, there is a possibility of the throttle getting frozen. I read this information on another forum and it all seemed logical. So, has anybody noticed a drop in MPG, or any other problems when using a CAI during the winter? My first thought was they are getting a drop in MPG just because of winter gas...any input is appreciated!
Old Nov 2, 2012 | 02:08 PM
Rottidog's Avatar
Do you have a heat shield installed? If not, I think the engine will actually warm up faster because it'll be drawing in the air under the hood which will be warmer than the outside air. It should have the opposite effect that we tell people about a CAI & NO heat shield drawing in the warmer air under the hood than the cooler air outside.
On mine the stock air box was fed through a (kind of) small hole behind the DS head lights. With a CAI & no heat shield it was pulling in the warmer air under the hood. Making it warm up faster & too much so in the summer hauling a boat at highway speeds etc.
Old Nov 2, 2012 | 02:12 PM
Vader's Avatar
Vader is on a distinguished road
When I drove my BMW in the winter I left the CAI intake on. I didn't see any adverse effects with it so I don't see a reason to remove it.
Old Nov 2, 2012 | 03:46 PM
chris015's Avatar
man,once your engine warms up (which doesnt take long) it'll be sucking in warm air anyways. Throttle wont freeze due to the engine being hot. Id only be worried if you'll be in -5 temps.
Old Nov 2, 2012 | 04:11 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Its fine leave it in...
Old Nov 2, 2012 | 06:00 PM
50lb_cat's Avatar
Yes, it does have a heat shield. I wasn't really buying into the throttle freezing, but the part about the computer dumping fuel kind of made sense. Anyone experience this?
Old Nov 2, 2012 | 06:09 PM
Joshs4x4's Avatar
Its fine your computer does fuel trims from the o2 sensor. 10 years with mine its fine
Old Nov 2, 2012 | 06:11 PM
The PCM can adjust fuel mixture acurately down to -40F and up to ~20K' ASL. As long as you're within in those, it shouldn't be a problem
Old Nov 2, 2012 | 06:28 PM
Rottidog's Avatar
Ok, so if you want it to warm up a little faster & depending how cold it gets where you live - then remove the heat shield for the winter.
Before PCM's etc I remember engines that had a bi-metal spring on the intake with a flue/damper that was fed off a metal flex hose that went to a shroud around an exhaust manifold in order to warm the incoming air for the engine.
When the air was cold it would allow the air to enter via the shroud over the manifold. When it was warm enough it would turn the damper so cool air could enter the intake.
Old Nov 2, 2012 | 07:03 PM
50lb_cat's Avatar
Thanks guys! I knew I would get some answeres here lol.
