Cold Air Intake Troubles....
Installed the throttle body spacer and got it to fit. it is VERY tight and is pretty much just riding on the bottom of the filter now. it is still too tall to actually mount the pipe properly. so i ordered a K&N filter that is about 2.5 inches shorter than the spectre filter that was with the kit. that should take care of any issues that are still there. made no modifications to my heat shield. thanks for your help
No, this happened to me last week actually. The 2 inch body lift raises the body up and so the engine components sit a little lower. In turn the plenum sits too low for the intake system to fit in the engine bay. I had this happen to me with a Spectre cai and I assume the K&N is very similar. So in order to counteract this, the easiest solution is a throttle body spacer as this created a lift for the plenum and corrects the plenum sitting too low.
With my home made intake that was made before the BL i didnt have any problems after the BL. i think i might have drilled a new hole in the core support for the heat shield that was a little lower but that rubber pipe for the intake is flexible enough to cover the 2 inches.
Edit: Oh.. Derp. The K&N CAI gets rid of the that rubber pipe. Ok forget what i said lol.. easiest solution is the TB spacer
Well just thinking about it... if you drill a new hole in the core support so the heat shield can sit lower i dont see why there would be a problem. you just might not be able to use that stud that the heat shield also attaches to.
The op and I had troubles specifically with the spectre kit. The kit hit the bottom of the body inside the engine bay and still needed another two inches or so to fit. One of the problems with the spectre kit is the filter size. That filter is half the size of the engine bay! Just unnecessarily big. This coupled with a low sitting plenum and you are screwed. So that's why a sshorter filter and throttle body spacer for this kit is needed.
Edit: This has nothing to do with the heat shield. The heat shield fits fine. The problem is the body inside the engine bay.
ravenhurst
15
Apr 26, 2009 07:53 AM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
