Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Cutting an K & N filter to fit ?
Old Mar 17, 2012 | 02:34 PM
xgiovannix12's Avatar
Default Cutting an K & N filter to fit ?
Hey every 1
This is going to sound sick but I just wanted opinions and ideas how to do this .
As you see i got my bronco home and i found an K & N filter in her
I wanted to put this filter in the blazer but its about 1 inch longer then the blazers original one
is it worth cutting it to put it in the blazer ? how would i cut it ?
and yes it needs to be cleaned =P
Old Mar 17, 2012 | 02:55 PM
chris015's Avatar
i guess if you wanted to hack around on this is cut it with a bandsaw for a even cut,then get a can of rubber coating,cover the end,then stuff it in,then seal around the edge with silicone.
OR buy my k & n cone i have laying out in the garage that will fit for cheaps lol
i wouldnt try it,it'll only mess up. Sell it on craigslist for 20 bucks.
Old Mar 17, 2012 | 02:58 PM
yea i was debating on it
I really wanna do a Cai on it in the future . But moneys always a problem
Old Mar 17, 2012 | 03:20 PM
pettyfog's Avatar
wow.. is that all the deeper they are? They really got you guys bitin'. Well, whatever...
Well, if you really want to do this...
Wash clean
Get left or right hand old metal snips*.. tube clear auto silicone.. wax or oiled paper 4" wide and 2 1/2 times longer than width of box
Measure both boxes, subtract one from other. add 1/8 inch to result.
Measure in that amount from outside of pleat lip. Cut with shears. Cut remainder from pleat lip close as possible. Less than 1/8 sticking out.
Test fit in airbox
Reform pleats.
Use spray solvent/ intake cleaner to clean joining parts. Lay 4" strip wax paper over one end of airbox, form inward to avoid tear with filter inserted. Lay big=*** bead silicone on end of filter. Make several rows touching if nec'y.
Put end against rest of filter, lay it in box, fold rest of wax paper over it and clamp top of airbox on. Forget about it for at least 12 hours.
*WITH PERMISSION!!! Tin snips supposedly should not be used to cut wire. and screening is wire. If they arent yours, ignore my warning if you want.. but..
Old Mar 17, 2012 | 03:38 PM
eh i think imma wait for the cai =P
and i never bought this filter it came with the bronco my friend gave me
other then that i think the blazer could wait =P
I did clean it tho ... and its in the sun as we speak
JohnBarJB
Sep 28, 2020 07:34 PM
96jimmyslt4x4
May 25, 2011 05:35 PM
rlott43
May 10, 2009 06:30 PM
KA3AX
14
May 12, 2006 05:07 PM
blazerscooby
Mar 19, 2006 02:52 AM
