Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
dual exhaust
Old Dec 18, 2009 | 07:58 PM
neo71665's Avatar
Is it pipe or tubing? Whats the wall thickness. Using regular pipe is gonna be a bit overkill and add a ton of weight to the exhaust, better make sure you add extra hangers to support it. Also one type of tubing or pipe may say 2.5 but is that external or internal measurements?
I toyed with the idea of using 2.5 EMT (yes I'm and electrican) cause I can get it free and can bend it myself. Our tubing size for 2.5 is actually 2.75 so normal exhaust clamps and stuff designed for 2.5 wouldn't work.
Old Dec 18, 2009 | 11:02 PM
Phil's Avatar
Personally, I go by the inside wall to inside wall measurement- hence why I call it pipe. If its from outside to outside measurement its a tube. Atleast thats what I was taught anyways. Could be wrong but thats always how I've always heard the difference between pipes and tubes explained. You probably will want to grab an extra hanger or two anyways just incase one is in not so good condition depending on the mileage or year of your truck. Make sure you get the pipe mandrel bent and not crush bent.
Old Dec 19, 2009 | 08:08 AM
longslide's Avatar
longslide is on a distinguished road
it's 14 ga. it mic'd at .0781 wall thickness and it 2.5 inch od.
Old Dec 19, 2009 | 08:52 AM
neo71665's Avatar
The difference between pipe and tube is not the measurement but how its made. Tubing was a flat sheet rolled with a seam in it. Everything to deal with electrical is measured from inside conduit (pipe) and EMT (tube).
Old Dec 19, 2009 | 02:09 PM
Phil's Avatar
Saved to computer for future knowledge. Learn something new everyday.
the_mind
26
Nov 26, 2008 12:45 AM
lucky03602
Sep 5, 2006 10:45 PM
Mylo_T_Cat
Mar 19, 2006 04:56 PM
blue_green_rider
Nov 17, 2005 07:11 PM
downhilryder
Oct 27, 2005 02:21 AM
