Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Muffler Help
Old Oct 5, 2025 | 04:15 PM
Gene H's Avatar
Gene H is on a distinguished road
Default Muffler Help
I'm asking the group for some help. I have a 2001 Blazer, 4-Door. Looks like my exhaust pipe is detached from my muffler due to corrosion. It may be the original. Most shops want to install a whole new muffler and have proved high quotes. Is there a way to just get a new tailpipe? Thanks
Old Oct 6, 2025 | 03:02 PM
int3414's Avatar
int3414 will become famous soon enough
after market muffler and tail pipe probably not much money, with that kind of rust surprised rear cover and fuel and brake lines aren't leaking and frame shot
Old Oct 7, 2025 | 10:48 AM
El_Beautor's Avatar
The muffler outlet is very rusty too, so a shop won't be able to weld a new tailpipe to it. Clamping a new pipe to that rusty outlet will just ruin both.
If you cannot afford a new exhaust system, as a temporary fix until you can replace the rusted out muffler would be a clamp-on joint. This would slip over the end of the muffler outlet and the tailpipe end, then clamp down onto them to hold them together. Most automotive stores have kits for this.
Be aware this is a temporary fix at best while you save up a bit to repair it properly. Your tailpipe is extremely rusty, and will continue to deteriorate. A clamp-on bandaid will give you a few months to a year. I doubt it will go longer than that.
antman94
Apr 9, 2012 04:35 PM
02BeachBlazer
Jan 15, 2011 09:44 AM
86Blazer4x4
Feb 6, 2010 07:07 PM
fla_blazer4x4
Jan 21, 2008 01:09 PM
