Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
possible flowmaster exhaust problem? Maybe something else?
Old Feb 6, 2010 | 07:42 PM
okstud's Avatar
okstud is an unknown quantity at this point
Thanks for the reply, do you have any advice on how to check on that problem. The issue is very sporadic. Im not sure if that makes a difference. Since replacing the cat it has been somewhat better. Its hard to determine b/c sometimes it accelerates just fine. Thanks
Old Feb 6, 2010 | 07:49 PM
Without any codes, it would just be a guess... I would look at having the coil and ICM tested to make sure they are working properly. Most autoparts stores can do this at no charge. Have them test them 10+ times in rapid succession to really get them up to temp.
Old Feb 14, 2010 | 06:38 PM
okstud's Avatar
sorry about all the threads, i thought it would be a better way of finding a solution.
Old Feb 14, 2010 | 08:56 PM
Phil's Avatar
Definitely try Kyle's advice. He was spot on with my gf's Galant the other day. After that if its still an issue, as I said in your other thread, maybe see if the 02 sensor is gunked up. I had to do this on my Firebird, so I assume since that is a GM also, that the method would be the same. I haven't had to try this on my Blazer so IDK if it is infact the same process, but anyways- unscrew the sensor, take a clean paper towel or an old shirt thats clean (thats what I did) and just wipe everything down and get off as much dirt as possible. Re-install sensor and see if it helps any. Do this to the pre-cat's and main cat's 02 sensors. I noticed my Firebird ran smoother after I cleaned its sensor.
Old Feb 14, 2010 | 09:21 PM
okstud's Avatar
ok, thanks for all your help!!!
N3ROST4R
Apr 19, 2011 02:38 PM
sgtbrum
Dec 18, 2006 11:29 AM
USMaverick101
Nov 17, 2006 04:06 PM
mont1340
Feb 11, 2006 10:37 PM
blazergirl15
Jul 9, 2005 03:26 AM
