'01 Jimmy Lift
Old Feb 14, 2010 | 09:11 PM
tmurph01's Avatar
tmurph01 is an unknown quantity at this point
Question '01 Jimmy Lift
I don't post on here much, but I do visit a lot to read up on stuff. I have been thinking of lifting my Jimmy for a while now to run larger tires. After seeing rebeljimmy96's pics of his, I was sold.
I plan on doing the same thing he did which will include:
PA 2" Body Lift
Fabtech 1.5" Shackles
1.5" T-Bar Crank
According to his thread, he has no problems running a 31" tire with this set-up.
Now, I have 2 questions:
1) His pics are the only ones I could find with this set-up. Is anyone else running the same one? If so, chime in and tell me how you like it and if you have any rubbing issues. If you have pics, I would like to see them also.
2) If I move up to a 31" tire, how do I go about reprogramming the speedo?
Old Feb 14, 2010 | 09:18 PM
Quik's Avatar
Quik is on a distinguished road
As for speedo I use Hptuners to recalibrate the speedo along other parts of the tune.
i run a true measured 32" tire with Tb crank/shackles and 2" body lift. You should be able to clear 31s easily with what your wanting to do
Old Feb 14, 2010 | 09:37 PM
tmurph01's Avatar
Okay, that is good to know.
While browsing summitracing I noticed they had ad-a-leafs that will give about 1"-2" of lift. Would these be better than doing shackles? Pros/cons?
Old Feb 14, 2010 | 09:42 PM
Quik's Avatar
ive never personally used a AAL but using another spring to increase height is also giving you increase payload creating a stiffer ride. If you want stock feel for a ride then shackles would be your best bet. if you want a stiffer ride then AAL would work for you as well.
if you have sagging springs like i do then replacing your springs all together with either low mile or new ones will give you height as well
Old Feb 16, 2010 | 09:05 PM
tmurph01's Avatar
I am shooting to do this during the month of May when it warms up. If anyone who has done a body lift lives around the eastern panhandle of WV it would be nice to have some help on this..
Old Feb 16, 2010 | 10:27 PM
NVANZEE's Avatar
I dont think you will need a programmer to adjust the speedo for 31s. I remember playing around with a Tech II and saw that 31s where an option to set the tire size to. Im assuming its because that is the stock size on a ZR2. So a dealer should be able to fix it for you.
Old Feb 16, 2010 | 10:48 PM
tmurph01's Avatar
I already planned on getting a PCM tune around this time, so I was going to have them reset it for 31" tires at that time. But this is good to know!
Old Feb 17, 2010 | 10:34 AM
Benedict1337's Avatar
My speedometer is pretty on. I have the tbar crank and shackles minus the body lift with 31's if you want to check out my blazer. I'm thinking about doing a body lift sooner or later because I have a little bit of rubbing issues with the 31's
Old Feb 17, 2010 | 10:43 AM
99blaz's Avatar
99blaz is on a distinguished road
Yea I belleive like nvanzee said the tech II is capable of doing it because of the ZR2s but if your getting your pcm tuned anyway you should be set. And wolfpack also has a tbar crack and bodylift as well as some other people.
Old Feb 17, 2010 | 11:20 AM
leeclark's Avatar
leeclark is an unknown quantity at this point
i have just a 2 inch lift (shackles and tbar) and i'm running 31s barely any rubbing so yeah 31s will fit easy with 2 inch body lift plus the shackles and tbar. post some pics when you get it lifted.
bdude273
Nov 22, 2013 08:30 PM
Az_S15
Tires and Wheels
Jul 16, 2013 03:29 PM
Dunkshouse
Apr 25, 2013 07:32 PM
LowLife
Jan 24, 2010 11:57 AM
birdsfan82
Lifting Tech
13
Oct 31, 2009 08:56 PM
