2" body lift?
Old Aug 10, 2009 | 07:31 PM
matthew.chapman1's Avatar
matthew.chapman1 is on a distinguished road
Default 2" body lift?
Hey guys,
Just wonderin....i just purchased a 2000 LS Blazer 2Dr 4X4
I am looking into getting a 2" body lift, but in some of the lift kits i saw that i might possibly have to do some modifications with my Air intake or air intake hose...just wondering if anyone has ran into this or heard of this. Also is there anything that i need to do after the lift is installed? alignment? or anything at all.
New to this so thanks for all the help.
Old Aug 10, 2009 | 07:41 PM
AJBert's Avatar
I had to mod the heat shield on my K&N FIPK, just cut the hole in the shield two inches lower in the shield. You won't have to worry about getting an alignment or anything else, unless you already have a problem before you have you start.
Old Aug 10, 2009 | 07:57 PM
oktain's Avatar
Alignments are only for suspension lifts, you`re not even touching the suspension with a body lift.
If you have the stock airbox, it`ll move with the body, if you have an aftermarket intake with the solid piping then you`ll have to do like AJBert because things will get strained because the mounting points for any intake are part of the body.
Hope this helps.
Old Aug 10, 2009 | 08:20 PM
wlorton's Avatar
Not to Hijack... but just to bring up another perspective....
So... If you do use a body lift... are there any adverse effects?
Old Aug 10, 2009 | 08:45 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
as long as you install everything correctly you shouldnt have anything to worry about.
Old Aug 10, 2009 | 09:33 PM
wlorton, not hijacking at all, thats is basically what i wanted to know as well, thanks guys for all the help.
Old Aug 11, 2009 | 07:22 AM
oktain's Avatar
Higher center of gravity = slightly more prone to roll overs... That's the worst I can think of that makes any sense. You shouldn't be driving a lifted Blazer like a sports car anyway lol.
Old Aug 13, 2009 | 12:21 AM
AJBert's Avatar
Also leads to wanting to more mods and less cash in your wallet.
Old Aug 13, 2009 | 01:54 AM
wlorton's Avatar
So my girlfriend's grandma had a blazer... back in the day when they was new.... I think a 99 or 98.... Well she is a notorious driver.... going around a corner... much too fast.... and rolls it.... oh.. and the crazy part was that it was an icy road...
Old Aug 13, 2009 | 01:56 AM
jsmz's Avatar
Banned for childishly attempting to delete all his posts
jsmz is an unknown quantity at this point
that is the truth. money goes fast, but its worth it in the end, i hope anyway. im not finished with mine yet but im close.
but the body lift is pretty straight forward, just follow the instructions and use an electric, or air impact wrench (saves alot of time)
