2 inch suspension lift
Old Mar 2, 2018 | 12:04 AM
Dlewis's Avatar
Dlewis is on a distinguished road
Default 2 inch suspension lift
Hi every one. I have been around the lifted truck seen for my hole life but never installed a real lift kit. My question to all is do i have to drop the transfer case on 1997 chevy blazer when i do a 2 inch suspension lift with a 4 inch body lift? Also where is the better choice for buying the kits?
Old Mar 2, 2018 | 06:49 AM
newguy's Avatar
you will also need different upper arms to help with ball joint angle and longer shackles in the back. And never heard of 4 inch body lifts for blazers
Old Mar 2, 2018 | 12:04 PM
chevyriders's Avatar
4" body lift is excessive on any vehicle imo. I wouldn't go further than a 2 inch body lift especially on an s-series.
If you want to do a 2 inch lift just buy the rough country 2.5" kit that comes with the differential drop bracket, and proper upper control arms.
If you're looking to get 6" of lift, i woild just get a 6" suspension lift. Rough country and superlift have 6 inch kits available.
Old Mar 2, 2018 | 01:00 PM
I did maybe not quite, but almost, a 2" lift on my Blazer. I used the Rough Country upper control arms, a torsion bar adjustment and new rear shackles. It was all pretty easy except for getting bolts for the rear shackles out. (I had to use LOTS of penetrant.) My .sig file has some to of the details.
Here is my write-up on what I did: https://blazerforum.com/forum/builds...on-lift-95744/
Old Mar 2, 2018 | 11:22 PM
Dlewis's Avatar
Default Thanks
Well i just learned a few things here. Thanks everyone. I do have one concern. The ruff country lift kits. I was informed that they are not that great. Durability is what i am needing. I tend to get really rough with my vehicles. I have the tendency to push as far as possible. Four and four is best. I will take that. I just need to be sure its going to last. Thanks again everyone.
Old Mar 2, 2018 | 11:59 PM
I'm curious as to what you learned about the 2.5" RC kits that make them not so durable. I ask as I don't think I've heard much about them having any weaknesses.
What I have heard is that those who are serious about having a really tough 4x4 in a Blazer get rid of the the IFS (independent front suspension) and instead install a solid axle. Solid-Axle Chevy S10 Blazer
Have you looked into that?
Old Mar 9, 2018 | 06:12 AM
carid's Avatar
Former Sponsor
carid is infamous around these parts
You may want to check our body and suspension lift kits available for the 1997 Blazer here: https://www.carid.com/1997-chevy-blazer-lift-kits/
98BlazerBadass
Tires and Wheels
Nov 17, 2016 04:23 AM
Coleman Mason
Tires and Wheels
21
Mar 1, 2016 05:26 PM
BackwoodsBogger14
Lifting Tech
Mar 26, 2014 08:45 PM
FirePhage
Lifting Tech
Feb 19, 2012 11:57 PM
