2000 2d 2wd Blazer, Whats a good body lift?
Old 02-24-2010 | 08:48 PM
2000blazerdudeman's Avatar
2000blazerdudeman is on a distinguished road
Default When?
Ya man, when i put the spacers in (ill do both), can i do that and in a few months do the body lift, or should i do this all at the same time?, and how can i learn more about this (the spacers). My buddy is better at this than i am, but i still would like to learn more... thanks for the help.
Old 02-24-2010 | 11:13 PM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Default lift
Nah it don't matter when you do it really. I did mine separately. But I don't think there are any build threads on here about it I should of done one. What do you want to know more about I can tell you whatever you need to know
Old 02-25-2010 | 06:18 PM
Default shackles and spacers
Hey what spacers/shackles should i use? But ive noticed you have been giving advice for the 2 spacer thing, whats you advice for the bottom spacer?
Thanks man...
Last edited by 2000blazerdudeman; 02-25-2010 at 06:34 PM. Reason: forgot to put something
Old 02-25-2010 | 11:59 PM
Default bl
The spacer's I'm referring to for the coils are the polyurethane donut looking spacers, there 9bucks at autozone and advanced and pepboys. Are you meaning what spacer for the bottom of the coil? If so you use the same spacer as the top just zip tie it on around the bottom of the coil. Zip tie the top spacer on the coil too so when reinstalling everything they don't go out of place. Any shackle will do the trick, if you have an auto store nearby go there, I've found that Pepboys has the nicest ones. Just get some 2'' lift shackles, really easy to install, I got a brand new 2'' lift shackle kit from pepboys for 35bucks. Hope that helps let me know if you have more questions, I've done every trick when lifting a 2wd
Tinted
Lifting Tech
12-31-2011 11:08 AM
ericthughes
Lifting Tech
10-13-2010 10:56 PM
gtmci84s
Lifting Tech
02-16-2009 11:25 PM
stevo
Lifting Tech
28
12-07-2008 07:18 PM
blazinfast
Tires and Wheels
11-24-2006 07:06 PM
Quick Reply: 2000 2d 2wd Blazer, Whats a good body lift?
