broken bolt?
Old Feb 20, 2010 | 05:48 PM
Green Blur's Avatar
Green Blur is on a distinguished road
Default broken bolt?
has anyone ever broken the head off their tbar adjusting bolt? mine was maxed out and my buddy didn't know it and broke it. Any ideas how to get it out? Where to get new bolt? any help would be greatly appreciated. Oh, it is a 96 2dr LS with 2"body and 2" shackles and tbar tweak with 31's.
Old Feb 20, 2010 | 08:00 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
1. drill it out.
2. weld a nut onto the end and spin it out,
3. replace the adjuster
Old Feb 20, 2010 | 09:04 PM
Green Blur's Avatar
thanks. where might I get a new adjuster? I have looked online but only find tbar mounts, not adjusters or bolts. any ideas? I prefer using a new parts instead of junkyard if I can find one. Thanks again.
Old Feb 20, 2010 | 09:28 PM
its not exactly a part they will wear out or break save the money and get one from a junkyard, sand it and paint it if you want it to look new
Old Feb 20, 2010 | 10:28 PM
ABN31B's Avatar
if you insist on new... try Rock Auto.
Old Feb 23, 2010 | 09:07 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Best bet would be to jack the truck up and use an easy out to back the bolt shaft out. The heat from welding a nut on could (not likely) heat the shaft and possibly make your situation even worse.
Old Feb 24, 2010 | 03:37 PM
Green Blur's Avatar
ok, checked rock auto online but didn't find any adjusters. could they be called something else? Anyone know?
Thanks A_tack, I appreciate the idea.
Old Feb 27, 2010 | 01:10 PM
tony991's Avatar
tony991 is on a distinguished road
Old Feb 27, 2010 | 06:19 PM
Green Blur's Avatar
Thanks tony991, I do appreciate it but I gave up on a new one and went to indy pick a part today and got a used one. Thanks 4 the advice tho.
jonwilliams
14
Nov 10, 2021 09:05 PM
ComputerNerdBD
17
Apr 18, 2018 08:57 AM
supersport_s10
Performance & Brainstorming
Nov 11, 2012 08:41 AM
wraithklewn
Aug 21, 2009 11:19 AM
