2000 blazer lift help!!!!
Old Jan 14, 2009 | 09:04 AM
greenjimmy's Avatar
greenjimmy is an unknown quantity at this point
Default RE: 2000 blazer lift help!!!!
yup, i already have the shackles and now i am just waiting on the wheels and tires. i am going with soft 8 16" with a 5" backspacing. and i am going with 265/75r16 cooper st.
Old Jan 15, 2009 | 04:09 PM
RIOT_707's Avatar
RIOT_707 is an unknown quantity at this point
so if i get a 2" BL an 31" tires on a stock blazer..will it have good clearance??
like will there be much rubbing
Old Jan 15, 2009 | 08:41 PM
B chevy99's Avatar
B chevy99 is an unknown quantity at this point
I was told before that cranking to torsion bar to lift ur ride height created front end ware, or is that why u stated 1.5" max? If I purchased a 2" body kit plus the shackles and cranked the torsion bar 1.5", how much would the ride quality change? So with the 2" BL and 2" SL i should be able to run on 31 x 10.5's without needing to regear or trim right?
And the tires i mentioned before are 33 x 10.5's and are buried under a ton of snow.
Old Jan 16, 2009 | 05:56 AM
nj4x4blaze's Avatar
ORIGINAL: B chevy99
It is true that cranking the torsion bars will create ware if you max out the torsion bars. You can safely go up to 1.5" in the front. But remember you have to get a wheel alignment after you crank the tosion bars. If you plan on running 31's, you don't need to regear the truck but anything higher I would highly recommend upgrading them to 4.10's.
Old Jan 16, 2009 | 01:04 PM
B chevy99's Avatar
If i were to used 2" shackles on the back and crank the T-Bar 1.5" would it not slope to the front quite a bit?
Old Jan 16, 2009 | 02:23 PM
greenjimmy's Avatar
yes, that is correct.
with the the 2"sl and 2"bl, u should be able to clear 32 with minner triming. 33 with more trimming. there are a few ppl running 33 with that kind of lift on here. depending on what size tire you are running, plus the lift you are adding, you will probably get 4" of total lift in the front.
Old Jan 19, 2009 | 10:32 AM
jeepster82's Avatar
jeepster82 is an unknown quantity at this point
36's with no trimming, its going to cost alote trust me
http://i496.photobucket.com/albums/r.../blazer001.jpg
Old Jan 23, 2009 | 06:51 PM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
Just my 2 cents...
Add-a-leafs > Shackles
31's are OK as is
32's regear
33's Play easy- axles recomended
35s axles required
Old Jan 23, 2009 | 06:53 PM
Nice thing about shackles is they really do not mess with your ride quality all that much.
TJnorcal
Suspension Tech
May 29, 2013 09:06 AM
SmoyMoose
Mar 30, 2010 07:41 AM
SmoyMoose
Lifting Tech
Mar 11, 2010 09:57 PM
COUNTRYBOY061488
Aug 28, 2008 07:54 PM
jessesjimmy
Suspension Tech
Jan 27, 2007 01:20 AM
