2002 2wd
I'd recommend a body lift to start with.. see how you like it. A lot of the guys here run Performance Accessories Body Lifts, they're cheap and you can most likely install it yourself. If you decide you want bigger/better (and more expensive) things check out some suspension lifts.
You do not need a 4X4 to have a lift. I've seen plenty of 2wd s-10's and blazers lifted. I have a 97 with a 2" B/L and a 2" suspension lift going in next week. Start with a body lift, it will not break the bank and if your reasonably mechanically inclined you can install it yourself in a weekend.
skygodtj
May 23, 2012 09:08 PM
mr_dbc
Sep 16, 2009 01:17 PM
Jorgen
Nov 6, 2007 03:06 PM
