2003 with 31x10.50x15
Old May 3, 2015 | 06:17 PM
Donny Ray Hedge's Avatar
Donny Ray Hedge is on a distinguished road
Default 2003 with 31x10.50x15
im wanting to get wheel adapters 2" and im wondering if i need any kind of lift to do this....right now at full turn i rub on the INSIDE so i was wanting to widen then width track and give it a better stance?
Old May 3, 2015 | 06:21 PM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
You'll probably have to trim the front and back of the fender so it won't rub there as well.
Old May 3, 2015 | 06:35 PM
i have 31x10.50 15 inch factory rim and no rubbing in the rear and the fron it rubs on the inside....
Old May 3, 2015 | 08:15 PM
newguy's Avatar
But spacers will push the tires outside the wheel well and they will rub, trust us
Old May 3, 2015 | 08:45 PM
ok thats not a big deal...ordered 2 inches in the back and 1.5 inch up front to even the wheels out....
Old May 3, 2015 | 08:53 PM
AJBert's Avatar
They will still rub up front with the spacer. You either need to lift it or break out the sawzall and do some trimming.
Old May 3, 2015 | 09:18 PM
shouldnt have to cut to much off the front i wouldnt think?
Old May 4, 2015 | 03:58 AM
newguy's Avatar
Gonna be more than you think. I had a 98 4 door with 2 inch body lift and 3 inch susp with 2 inch spacers, lift and still had to cut an inch off to fit 31x10.5s
Old May 4, 2015 | 07:35 PM
im going 1.5 in front and 2 in rear....
Old May 4, 2015 | 08:03 PM
newguy's Avatar
good luck
