29x10.50 test fit
Old Nov 12, 2007 | 05:12 PM
  #21
cyukio's Avatar
cyukio is an unknown quantity at this point
Default RE: 29x10.50 test fit
first of all the tires that i want to run are super swamper tsl sx's and the reason why they dont fit is because for that particular prand of tires the 30s only come in 11.50 and by running my 15x10" rims they stick out so much that it hits the plastic bumper in the front and the rear fender by the doors, if you think that you could fit those tires try putting a 11.50 tire on a 15x10 rim and mount that on your truck. my truck is only a 4x2 so looks is pretty much all i got so this is the look that i want i dont want narrower tires i like the beefier look. and by the way im in hawaii so yes no snow and like i said im 2x4 so why would i even chance the mud.
ORIGINAL: kankoon52
why would you put 29x10.50 tires on? why not somethin atleast bigger. and if not i would go with a narrower tire. wider is not always better. in mud and snow a narrower tire will do better. id get some 31x10.50 atleast for that it looks goofy with such small tires. how didnt 30's fit? with all that lift they should fit easily with very minimal trimming i would think. i have a 4x4 and only a 2" torsion bar crank in the front and im putting 31x10.50s on it
Old Nov 12, 2007 | 05:14 PM
  #22
cyukio's Avatar
my hero
ORIGINAL: RCars2
ORIGINAL: kankoon52
......HUH? Where do you get that rational? If you have a narrower tire you have more weight on a smaller area and thus you will sink faster. Additionally you have less surface to grip with so traction for accellerating and stopping is significantly less. Im not sure where you learned that from but speaking from experience, wider tires take the elements a lot better.
Old Nov 12, 2007 | 09:01 PM
  #23
ORIGINAL: cyukio
my hero
ORIGINAL: RCars2
ORIGINAL: kankoon52
I wouldn't pull the hero card just yet...
RCars2, you do not have more weight on a smaller area. You have the same weight on a smaller area which, depending on the conditions and the limits of traction you are already at, wider can cause problems as well. It all depends on whether you are on-road or off-road.
While you may not see snow, others that read through this thread may. And they may be misled by statements such as "wider tires take the elements a lot better"... Since no "elements" were specified, that statement is false.
Old Nov 12, 2007 | 10:59 PM
  #24
cyukio's Avatar
first of all i never posted anything about the "elements" this whole post was to show that the 29s fit my truck. it was just a post to show everyone that was trying to help me with my problems of tire clearance the last couple of weeks to see that i got my tire clearance solved. second of all you dont come to a thread and flame somebody about their truck looking goofy, i think you should keep that comments to yourself. third you should read previous posts to know the whole story on why i had tire clearance problems with my 15x10" rims. im not trying to start problems i think this forums rocks but if youre gonna flame on someone hit up another forum.
ORIGINAL: swartlkk
ORIGINAL: cyukio
my hero
ORIGINAL: RCars2
ORIGINAL: kankoon52
Old Nov 13, 2007 | 08:21 AM
  #25
My reply was sort of disjointed, I wasn't referring to you, cyukio, when I made the statement about RCars2's misleading comments at the end of my post.
And let me just say, this is an open forum. When you post something, you open yourself up to the opinions of those reading/posting in your thread. You started this thread with pictures only, no text for questions, details, nothing... As such, you opened yourself up to each individuals interpretation of your goals for this thread. Were you asking for opinions? From any post up to the one where someone asks why you would want to do such a thing (didn't seem to be a flame to me), there was no mention of your intentions for this thread.
Also, as an asside, you do not need to quote every time you respond. You may want to try to clip out some of the quote of the quote of the quote items and just keep the parts that you are responding to.
Old Nov 13, 2007 | 12:17 PM
  #26
cyukio's Avatar
how did i open this post with pictures only? in my second post it explains why the pictures were up there. and the only reason why i had to post it after the pictures is because i dont know how to post pictures up too well im not very computer literate, hence i dont know how to clip edits.
Old Nov 14, 2007 | 12:01 PM
  #27
kankoon52's Avatar
kankoon52 is an unknown quantity at this point
when i said narrower tires get better traction i was meaning in some cases. ever notice what the military rigs run? usually narrow tall tires. because if you think back to highschool, a smallerfoot print creates more pounds per square inch which means more weight for traction. now if your mud bogging in a bottomless pit or in sandthen wider tires are going to be better because the wider tire gives you more flotation because it spreads the weight out over a larger foot print. but if your on some slick clay or a muddy hill side those narrower tires are gonna grip way better than some real wide tires. and when you say a narrower tire sinks faster that is the point so it sinks down to the hard ground and gets traction. like i said unless your mud bogging in some really deep mud a narrower tire is gonna do you more good in most cases.
bigdaddykane93
Jan 23, 2010 02:10 PM
wlorton
Tires and Wheels
Aug 23, 2009 06:12 PM
tomsblazer
Mar 21, 2006 11:45 PM
m00nwater
Feb 27, 2006 01:34 PM
Labinnac
Jan 24, 2006 08:24 AM
