6" Superlift
Old Mar 2, 2009 | 09:59 AM
redfan13's Avatar
redfan13 is an unknown quantity at this point
Default 6" Superlift
So, I've been seriously debating the 6" FIT Superlift for my blazer, and I've got a couple questions...
First off, i know I'd need to regear if i did the lift, so what would my options be to regear?
I have the front diff out ofmy wrecked 02ZR2 (3.73), i could throw in, but i ended up selling the rear axle out of it, so i don't have the gears out of the rear. Could i buy gears for the rear to match or what are my options there?
Next question: My buddy has a set of 33x12.5x15 Discover Cooper STT's he's looking to get rid of (i could get them for dirt cheap), but the superlift website says the lift will fit 33x10.5x15's will the extra 2" width cause rubbage?
And last question, has anyone here installed the lift before, and know what kind of work is involved? Its really not going to be an issue as my brother in law is very very knowledgeable and will be helping me throughout the process, i'd just like to know what i'm gettin my self into...
Old Mar 2, 2009 | 10:02 AM
jagblazer01's Avatar
Default RE: 6" Superlift
as far as gearing, your probably gonna want to step up to 4.11s. nj4x4blaze has the superlift on his truck....he should chime in soon
Old Mar 2, 2009 | 02:24 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
At full steering lock you may have rubbing at the bottom rear edge of front fender with the 33x12.5/15 tires. Nothing a little fender trimming won't solve.
And for gears I'd definitely recommend stepping up to 4.11 at least.
Check out this chart to help you select gear ratios...
http://www.4lo.com/calc/geartable.htm
This chart is very helpful too...
http://www.4lo.com/calc/geartire.htm
Old Mar 2, 2009 | 04:32 PM
nj4x4blaze's Avatar
Contact Randy's Ring and Pinion to purchase your gears. If you plan on running 33's I would suggest 4.11's. Ask the guys from Randy's for Yukon gears, that's what I am running on my truck. As for the tires, my 33's are 12.50" wide and they rub a little. Like SockJock said, some trimming and the issue was taken care of. If you don't wanna trim your fenders, then you can always do a 2" body lift.
Old Mar 2, 2009 | 11:11 PM
redfan13's Avatar
Alright cool, thanks for the help... Now i just have to save my money for the next couple of months, and will hopefully have enough.
98blazr
Lifting Tech
Apr 17, 2009 03:50 AM
NVANZEE
Lifting Tech
May 14, 2008 06:51 AM
Cmatt1605
Suspension Tech
May 2, 2008 06:53 PM
lennyblazer
24
Jul 17, 2007 10:55 AM
jagblazer01
Suspension Tech
Nov 22, 2006 08:12 PM
