94 blazer lift help!!!
Old Jan 25, 2009 | 07:55 PM
buggyblazer's Avatar
buggyblazer is an unknown quantity at this point
Default 94 blazer lift help!!!
I have a 94 s-10 blazer that is converted to a buggy. I cant do a body lift since my roll cage it welded to my frame. I want to get 4+ inches of suspension lift for it. Anyone know any kits available with this amount of lift.
Old Jan 25, 2009 | 08:25 PM
WolfPack's Avatar
Default RE: 94 blazer lift help!!!
You built it up as a buggy, but kept the IFS?
Old Jan 25, 2009 | 08:41 PM
bandidolenny's Avatar
Since it is already a "buggy" I would simply bust out with the sawzall and get to work! Then you can run bigger tires and not have to spend money on a lift.
Old Feb 10, 2009 | 10:48 PM
blazerman09's Avatar
blazerman09 is an unknown quantity at this point
i have a 94 blazer wit a 2 inch suspension and 3 inch body with tha back chopped off 2 look like a h3 hummer truck and wnt 2 go higher knw where i can get a cheap lift
Old Feb 10, 2009 | 11:01 PM
WolfPack's Avatar
Solid front axle swap
Old Feb 11, 2009 | 08:57 AM
i'm putting a flip kit in tha rearend so that my leafsprings are on the top of axel instead of bottom. i jus need 2 knw sumwhere 2 get a cheap lift for the front
Old Feb 11, 2009 | 11:07 AM
WolfPack's Avatar
There isnt any for a 4x4. You can only go 2' before the CVs get too steep. You would have to create a differential drop bracket to go any higher. Thats why SOA flips are usually only done with a full 5' or 6' lift kit.
Old Feb 12, 2009 | 06:59 PM
what is a soa. and how hard would it be to drop the differential drop brackets
Old Feb 12, 2009 | 08:29 PM
WolfPack's Avatar
SOA = spring over axle. Its the same as what youre calling a flip kit.
As for dropping the front diff, its only mounted to the frame in 3 places, so if you can handle a bit of fabrication, im sure you could do it.
But...after you drop the diff...then you have control arms to drop too so you keep your suspension geometry the same. Then...after you drop those, you have to relocate your steering. Then youre on to brake lines.
Basically...youre making your own 5' lift kit. Youd be better off buying one
TJnorcal
Suspension Tech
May 29, 2013 09:06 AM
SmoyMoose
Mar 30, 2010 07:41 AM
SmoyMoose
Lifting Tech
Mar 11, 2010 09:57 PM
texastrails
Suspension Tech
Jun 21, 2007 12:36 PM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
