97 2wd 2dr. lift????
Old Jul 27, 2009 | 08:56 PM
cueball's Avatar
cueball is on a distinguished road
Default 97 2wd 2dr. lift????
I'm looking to put 31" tires on my 1997 2wd 2door Blazer. I like the stock aluminum wheels so I will be keeping them. I don't do any off road driving, just want the ride height. What do you think my best options are??? Thanks for your input...
Old Jul 27, 2009 | 10:27 PM
mdehoogh's Avatar
With a 2WD, you don't have that pesky axle in the front to wear out and interfere with everything. I think the best way to go would be lift spindles in the front and an add-a-leaf in the back.
You could also use longer coil springs in the front and shackles in the back or a body lift.
Old Jul 28, 2009 | 02:01 AM
bandidolenny's Avatar
I would only do a body lift and some heavy duty shocks for those larger tires.
If you wanna go higher then do 3" lift spindles in the front and 2" shackles in the rear for that prerunner look and it will still have the factory stock ride.
Old Jul 28, 2009 | 08:11 AM
cueball's Avatar
I'm after the prerunner look as mentioned. Where can I get the parts to do the 2" lift shackles in the back and the 3" lift spindles in the front? Thanks for the help!
Old Jul 29, 2009 | 05:39 AM
nj4x4blaze's Avatar
Old Jul 29, 2009 | 09:24 AM
cueball's Avatar
Thanks for the links. What would give a better ride, the add a leafs or the shackles? Which would give me more height?
Old Jul 29, 2009 | 12:57 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
aal's will be stiffer when compared to shackles and if you buy 2" shackles or 2" aal's they will both give you 2" of lift.
SmoyMoose
Mar 30, 2010 07:41 AM
ajklein2
Tires and Wheels
Apr 3, 2008 12:22 PM
Canadian88
Lowering Tech
Mar 9, 2008 11:47 PM
vegasmason
Jan 13, 2008 06:56 AM
tnblazer
Mar 26, 2007 07:29 PM
