adding a leaf
Old Feb 4, 2009 | 09:56 AM
jayisonfire's Avatar
jayisonfire is an unknown quantity at this point
Default adding a leaf
hello all, just wondering if anybody out there who has added a leaf knows roughly what height is added with what width of spring? just curious to see if any variances are out there. im only looking to get around an inch or so. my truck is a 2002 2 door 4x4 and i have 31s on it right now with sitting stock. just lookin for a little input! thanks!
Old Feb 7, 2009 | 07:06 AM
SockJock's Avatar
SockJock is an unknown quantity at this point
Default RE: adding a leaf
I went to the junkyard and got an extra set of leafs from another blazer and pulled the leaf packs apart, cut the eyes off the longest leaf and slid it into my leaf pack. I got between 1 to 1.5" of lift from it.
Old Feb 7, 2009 | 08:51 AM
greenjimmy's Avatar
greenjimmy is an unknown quantity at this point
i went and got a procomp short aal. all i was looking for was to big the *** back up b/c it was sagging(from all the towing and hauling i do). it brought it back up and alittle more. i am running the same setup as you, stock truck with 31. i didn't notice a difference in hight until i put the 31 on. almost 11" of ground clearnce under the front crossmember and about 11 under the diff. do you rub at all?
Old Feb 7, 2009 | 12:45 PM
OILCOUNTRY's Avatar
OILCOUNTRY is an unknown quantity at this point
Short Add-A-Leaf from procomp. The kit is great and nice and cheap too.($55 CDN) If you do a search(Procomp Short ADD-A-LEAF)you can see whenI did mine. It picked my rear end up a good 1 and a half inches.I really didnt nodice a difference in my ride either. Easy to install and the most difficult thingI found was breaking the oldU bolts.
Old Feb 8, 2009 | 12:19 PM
greenjimmy's Avatar
yeah, that was the hardest. but the hardest thing for me, was the cold. i didit in 30 degree weather.i got mine for like$40 from carstuff.com
Old Feb 9, 2009 | 06:58 AM
thanks for the input guys. There is a place in town that cuts springs, and makes leafs and add a leafs, so i guess i'll just measure that main leaf and get that, only like 23 bucks canadian a side... also greenjimmy -> the tires do not rub at all when just sitting and turning the wheel, but they rub a tad on the very inside against the frame. its not too bad though, i just try not to cut em that far.
gitch93
Oct 24, 2012 12:07 PM
LucasMI
Jan 2, 2012 02:15 PM
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
95Jimmy
Lowering Tech
Sep 19, 2010 10:24 PM
DaleA
Suspension Tech
Dec 26, 2008 09:03 AM
