Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
adding a leaf
Old Jul 26, 2010 | 08:48 AM
95Jimmy's Avatar
95Jimmy is on a distinguished road
Default adding a leaf
I have a 95 GMC Jimmy lowered about 5' in the front and 4' in the back. I love the way it sits/looks BUT when I put 4 people in the truck and a bunch of other crap it bottoms out a little too easily. When I'm by myself or just have the kids it's fine. I also have 2 12's in the back in a big ported box which is a significant amount of weight. Other than raising it up with some 3' blocks could I leave the 4' blocks on it and add another leaf to the rear to stiffen it up some more? It already has 4 leaves. If so should I just go to the junkyard and grab some extra leaves off another Blazer or buy an add-a-leaf or ? Thanks.
Old Sep 19, 2010 | 08:21 PM
sjas00jimmy's Avatar
sjas00jimmy is an unknown quantity at this point
Try air shocks... You replace your shocks with them and run air lines.. I driled a hole in my bumper next to my license plate. You can hardly see it and it levels everything out when im towing. Costs maybe $100 and a 1 1/2 hrs of your time
Old Sep 19, 2010 | 10:24 PM
old skool luvr's Avatar
the only problem with sjas set-up, is you need to stop @ a gas station every time you want to put more weight in your truck-be it people, something you "just had to have" while you were out, whatever.
you can do the AAL, but remember the ride is gonna be quite a bit stiffer when empty (you alone, or just the kids). you can do the air shocks or bag it, just put a compressor up front so you can fill it as you need it.
considering how "new" your truck is, it's alot easier to get a kit that's been designed for what you're after.
but remember, you'll be paying for their R & D. so you can make it all home grown, or you can drop the $$$ on someone else's design,it all depends on your pocket, and ability to fab 'n wrench
gitch93
Oct 24, 2012 12:07 PM
LucasMI
Jan 2, 2012 02:15 PM
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
jayisonfire
Lifting Tech
Feb 9, 2009 06:58 AM
DaleA
Suspension Tech
Dec 26, 2008 09:03 AM
