another shackel question
Old Aug 1, 2009 | 09:50 AM
duvall45's Avatar
duvall45 is on a distinguished road
Default another shackel question
I am changing out my tie rods and cranking my t-bars while I have it jacked up. I have seen several posts about changing shackles to lift the rear but none of them that I have found say what stress it puts on the truck or how much you can go. I might put bigger shackles on the rear I want to see how it looks after I finish the front. If I do swap the shackles, will I need to change anything else like shocks or will they just have less travel? I would like to put on a body lift at some point but I have other repairs to do first.
Thanks
98 4dr 4x4
Old Aug 1, 2009 | 10:29 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
most guys go with 2" lift shackles and ive never heard of anyone having a problem due to lift shackles. if you go with a 2" or less shackle you wont have to change anything else such as shocks.
Old Aug 1, 2009 | 11:07 AM
duvall45's Avatar
So realistically it would be a cheep way to lift the rear. I want to lift the truck about 2" and put on 30" tires for looks only, I don't take it off road.
Old Aug 1, 2009 | 11:11 AM
mikeinwi's Avatar
adding shackles is probably the easiest/cheapest way to lift the rear.
Old Aug 1, 2009 | 06:34 PM
bandidolenny's Avatar
Some people just crank the front up about an inch and don't even mess with the rear... gets rid of the "nose down" look.
Trb
Feb 3, 2015 09:41 PM
suprsk8er2
Lifting Tech
Jan 19, 2012 10:11 PM
2001Jimmy
Aug 30, 2011 05:10 PM
chrishorton74
Jun 2, 2010 09:03 PM
redfan13
Mar 11, 2008 09:37 PM
