Body Lift
Old Jan 22, 2013 | 06:55 AM
  #31
Jamaroon's Avatar
Originally Posted by timo98gmc
I am ordering a body lift just wondering if there is interior stuff you need to do to get the body mount bolts out and does it mess with shifting linkage?
Only if they break taking them out. I had one break and had to make an access hole in my floor.
Shift linkage will be fine.
Old Jan 22, 2013 | 09:08 PM
  #32
timo98gmc's Avatar
timo98gmc is an unknown quantity at this point
Hey im planing an a body lift 2 inches do i need to o any interer stuff what will it do the shifting linkage
Do i need to do interior things when doing a body lift 98 jmc jimmy what does it do to shifting linkage?? And one help me 2 inches do i need any steering things
Old Jan 22, 2013 | 10:15 PM
  #33
Jamaroon's Avatar
Here's the instructions for the PA 2" Body Lift. Everything you need is in the kit.
http://www.performanceaccessories.co...ctions/152.pdf
Old Jan 22, 2013 | 10:44 PM
  #34
timo98gmc's Avatar
Do you need to lengthen steering lincage with a 2 inch body lift 98 gmc jimmy?
Old Jan 23, 2013 | 12:56 AM
  #35
HcHawks09's Avatar
No to both questions. All body bolts are completely accessible from the exterior. It is FAIRLY straight forward. Take off bumpers grill and skid plate. Disconnect anything that is attached to both the core support and the engine. Disconnect fuel neck from body. remove bolts from one side. Jack up place blocks and new bolts. Repeat for other side. Extend fuel necks. replace everything and use supplied relocation brackets when needed.
P.S. you will need a drill and a sawzaw to drill holes for 4x4 actuator and bumper brackets and to trim the bumper to clear brackets.
Read over the instructions. Take your time and give yourself enough time. One step at a time.
Old Feb 17, 2013 | 07:57 PM
  #36
kenny100034's Avatar
kenny100034 is on a distinguished road
I'm still waiting on my father to get the body lift done, its sitting in my room, going to do it in spring. I keep debating also doing the generic 2" shackle and tbar crank, but am going to wait until the body is on to see if I want more, or need more clearance.
Old Mar 11, 2013 | 12:02 AM
  #37
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
How about my brushguard its bolted to the frame?
Old Mar 11, 2013 | 12:33 AM
  #38
HcHawks09's Avatar
I believe it just depends check out this thread:
https://blazerforum.com/forum/liftin...h-guard-69127/
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
