Body lift?
Old Mar 22, 2013 | 05:38 PM
xgiovannix12's Avatar
Originally Posted by chestypuller
Personally ifs is garbage and would suggest solid axle conversion
you just said cut a frame and put it under your original frame. YOU said nothing about a SAS in your 1st post...
Old Mar 22, 2013 | 10:35 PM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
i was offering a cheap way to do a lift. SAS isnt cheap.
Old Mar 22, 2013 | 10:44 PM
Cheap and dangerous way of lifting it.... Not good...
Like they say nothings cheap Cant afford to do it right? dont do it period
Old Mar 22, 2013 | 11:36 PM
Banned
thats your opinion, ive seen this done several times around here and they come out better then the kits you buy from superlift and such. its all in the way you do it.
Old Mar 22, 2013 | 11:52 PM
I would like to see this way you speak of ???? how is it better then a sas?
Old Mar 23, 2013 | 12:18 AM
bdemutis's Avatar
bdemutis is on a distinguished road
Honestly cutting it and putting it under the origional sounds ghetto I misewell just get the steel and weld my own homemade lift lol. I'm just going with the torsion crank and shackles then I might just add a 2" or 3" body lift because I heard you can use the k5 lift if you make your own bumper brackets.
Old Mar 23, 2013 | 02:21 AM
Banned
heres a pic i found on the internet, same idea but they used an entire frame, im talking just use the front part, so its like a kit but the measurements are already done and mounts are factory
Old Mar 23, 2013 | 04:55 AM
newguy's Avatar
Yep, that will impress everyone
Old Mar 23, 2013 | 04:56 AM
newguy's Avatar
Ive seen guys cut the frome off the front of a junk yard blazer and bolt ot under the original front and it gives a 6" lift and is solid as stock
Please dont breed
Old Mar 23, 2013 | 12:26 PM
Banned
your ifs lift kits are the same thing but weaker and out of wack dimensions!
