Body lift Questions
Body lift Questions
The bolts that hold the body on in the 10 mounting points. What thread pattern are they?
Most likely will be a coarse thread metric thread. If I had a truck close by, I would pull a bolt and throw a profile gauge onto it.
12mm X 140mm is what the parts list shows for my 2" body lift.
Hmm 12mm is the diameter, and 140 the length of the bolt of course, if it is 12mm i bet it is 12x1.5mm its a pretty common thread, also the same thread as the lug nuts i believe...
Thanks.
Thanks.
