body lift spacer question
Old May 2, 2008 | 11:44 AM
stevenf's Avatar
stevenf is an unknown quantity at this point
Default body lift spacer question
I just started on my body lift and im curious as to how the spacers go on the frame/body. Do the spacers touch the frame and the body or do they need washers? The stock ones seem to be molded on the original bushing. Do I just put the 2" spacer in between the frame and the body, with no washers?
Old May 2, 2008 | 12:48 PM
Default RE: body lift spacer question
How many washers/spacers came in the kit?
Old May 2, 2008 | 12:56 PM
WolfPack's Avatar
I feel like that should be pretty well noted in the instructions, but I have not done a body lift, so I'm just speculating
Old May 2, 2008 | 01:54 PM
Yes, the instructions should call it out fairly well, but of the lift kits I have installed on fullsize trucks, the instructions are often photo copies of who knows how many other photo copies and the pictures don't always show very well.
What is the manufacturer and PN of the lift kit you are installing? That information might help us a bit...
Old May 2, 2008 | 02:15 PM
stevenf's Avatar
I figured it out, the 2" spacers had to be set on top of the stock bushing so it went as followed. Frame+Stock bushing+ spacer+body.
The instructions were rediculous! Take off the lower fan shroud, take off the rear bumper, take off the air intake system, undo the gas tank filler tube, unbolt the vacuum pump on th epassenger side fender well under the hood.
Each one of thoughs things was COMPLETELY unneccessary!!!!!!! I guess Ill know incase I have to do this agin.
Old May 2, 2008 | 03:13 PM
WolfPack's Avatar
thats good info to have! Are you taking pics?!
Old May 2, 2008 | 03:21 PM
Glad you got it figured out!
Old May 2, 2008 | 04:21 PM
stevenf's Avatar
No I didnt take any pictures. I will after Im done.
njerrils05@gmail.com
Lifting Tech
Sep 10, 2011 01:40 AM
djbass_mekanik
Headers, Intake, & Exhaust
34
Jul 6, 2007 11:58 AM
LittleDan911
Engine & Internal
Mar 23, 2006 01:35 AM
shawn_dh
Engine & Internal
Jun 13, 2005 04:16 PM
94Blaze
Engine & Internal
Jan 5, 2005 09:59 PM
