building shackles
Old Dec 27, 2007 | 02:13 PM
myronhntr80's Avatar
myronhntr80 is an unknown quantity at this point
Default building shackles
I have been told that when you want to get 2 inches of lift in the rear w/ shackles that you need to increase the length of your shackles by 4 inches. Is that true. The theory behind that statement is that you are lowering the back of the spring while lifting the chassis of the vehicle so you need to double up. Also how far will 2 inch shackle lift push the tire forward into the wheel well?
Old Dec 27, 2007 | 03:23 PM
Blazin_Jason's Avatar
Default RE: building shackles
It's because you are only lifting half of the spring. Here's a little post I did a while ago.
Old Dec 28, 2007 | 12:48 PM
Thanks for the post. From the looks of your pics it doesnt seem like it moved the tire forward in the wheel well much at all. That was my main concern since I just ordered a set of Mickeythompson Baja MTZ's in 31 10.50 15. I want to gain clearance not lose it. I will continue to build my shackles, and crank the t bar also.
Thanks again
Unlimitedsp
Jan 14, 2010 03:51 PM
dirtydave
Suspension Tech
Dec 18, 2009 04:21 PM
88s10Blazer
Sep 22, 2006 02:36 AM
Hanr3
Jul 26, 2006 12:27 AM
jagblazer01
Mar 15, 2006 07:58 PM
