Cheap lift
Old Jun 13, 2013 | 10:38 PM
A2D customs's Avatar
A2D customs is on a distinguished road
Default Cheap lift
I have a 98 blazer and I have a set of 31x10.50s bfgs wrapped around crugar -12 mm offset wheels I want put on it. will lifting the torsion bars and putting a 2 inch shackle lift look right and be able to turn I'm ok with a little rub
Old Jun 25, 2013 | 01:02 PM
01blazer16's Avatar
01blazer16 is on a distinguished road
I'm not sure but a 2 inch body lift would fit 31s
Old Jun 25, 2013 | 03:02 PM
KO-king's Avatar
KO-king is on a distinguished road
I have a 2.5" rouch country lift with 31" bfg and I had to do some decent trimming in order for me to turn without major rubbing. To be safe id go with a body lift and tweak the torsion bars up a little. not to much or it will cause front end wear!
Old Jun 25, 2013 | 03:20 PM
El_Beautor's Avatar
Most people need more than just a t-bar lift to clear 31's safely, especially if they're on low backspace rims. Like KO-King said, a t-bar lift, shackles in the rear, and a body lift should clear 31's fine. I did 31's like that for quite a while before I went up to 32's and had to start chopping my fenders.
Old Aug 3, 2013 | 05:51 PM
Stevenadamski's Avatar
Stevenadamski is on a distinguished road
I run 30s on stock rims with a tbar crank, stock otherwise and i dont rub until full lock. Ive got room too so im sure i could run 31s with no problems as is
Old Aug 4, 2013 | 07:01 PM
T...K21's Avatar
T...K21 is on a distinguished road
Just out of curiosity. All the 2nd Gen S Blazer and Jimmy were push button 4wd right? So when adding a body lift...you aren't fighting the t-case shifter on the floor, fan shroud, and brake lines.
I base my question on owning a couple 1st gen GMC S-pickups in the past.
Old Aug 4, 2013 | 07:21 PM
newguy's Avatar
You still have to mess with the shroud and brake lines a bit. t case stuff no
Old Aug 7, 2013 | 01:12 AM
HotRodHearseGuy's Avatar
HotRodHearseGuy is on a distinguished road
I've also got a '98 Blazer and currently running 31's on my stock wheels and only time it rubs and its only SOMETIMES, it at full lock. I'm running at stock height with no adjust on the t-bar.
FourX4 00
Lifting Tech
21
Jan 28, 2010 09:19 PM
drogg1
Lifting Tech
Jan 20, 2010 11:43 PM
toby42
Lifting Tech
Feb 21, 2008 02:32 PM
mudsliner
Lifting Tech
May 25, 2007 11:23 PM
danr
Suspension Tech
Jul 10, 2005 03:46 AM
