cheapest lift????
Old Feb 27, 2009 | 08:51 AM
mudboggers10's Avatar
mudboggers10 is an unknown quantity at this point
Default cheapest lift????
i have an 89 blazer and i wanna lift it up like 3" but i dont wanna do a suspension. any one know a good way to jack up and rear end and the front end for a really cheep price???
Old Feb 27, 2009 | 08:57 AM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Default RE: cheapest lift????
check out the lift kit list thread right under this one lists the different options and prices.
Old Feb 27, 2009 | 10:42 AM
RWRIGHT's Avatar
RWRIGHT is an unknown quantity at this point
if your wanting to go 3' i know a way you can get 3' up front but it makes a huge wear and tear on your front end...howver if you only go 2 1/2' your alright...this is called t-bar raising...for the rear you can buy a block to put in between your spring and axle. you can order what ever size you want
Old Feb 27, 2009 | 11:29 AM
Outsydr's Avatar
anything more than 1.5" on t-bars and you will be buying cv's and ball joints so often you'll want to own stock in the company, blocks dont raise these trucks only lower them (springs have to be on top of the axle for a block to lift they are under the axle on these) besides that the op said he did not want to do suspension lift.
Old Feb 27, 2009 | 03:51 PM
WolfPack's Avatar
outsydr ftw!
Old Feb 27, 2009 | 03:56 PM
RWRIGHT's Avatar
check out this post i posted earlier
Before & After T-Bar
Suspension Techit should help you mack a decision
Old Feb 27, 2009 | 05:48 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
You want a body lift. It doesn't affect factory suspension, doesn't cause additional wear and you can buy 2" or 3" body lifts. Check Performance Accessories website or visit Summit's website. You can also find bodylift kits on ebay at supercheap prices sometimes.
CraigSnedeker
Lifting Tech
May 15, 2011 08:18 PM
96jimmyslt4x4
Suspension Tech
Apr 18, 2011 10:40 PM
rockislife04
May 8, 2010 09:27 AM
Rottidog
Feb 21, 2010 12:59 AM
dimmuborgir6nik6
Mar 10, 2008 09:57 PM
