Coil spacers?
Old Nov 14, 2010 | 06:02 PM
Drewjharper1900's Avatar
Drewjharper1900 is on a distinguished road
Default Coil spacers?
So i am wanting to level the front of my 2wd jimmy. Ive seen on here that you can do this by inserting coil spacers into the suspension coils. However, nobody has touched on what spacer work the best,(i.e. provide the most lift). Im planning to put on 30" bfg's and i wana get the most clearance as possible. Out of these spacers, which ones would give the greatest lift?
http://www.amazon.com/Superior-18-80...gy_auto_text_b
http://www.amazon.com/Superior-18-12...gy_auto_text_c
http://www.amazon.com/Mr-Gasket-1284...=pd_sim_auto_5
http://www.amazon.com/Specialty-Prod...pd_sbs_auto_13
http://www.amazon.com/Mr-Gasket-1287...=pd_sbs_auto_1
Old Nov 18, 2010 | 11:56 PM
nismo_2005's Avatar
nismo_2005 is on a distinguished road
i would not run the spacers on a 2wd s series. the coild buckets are prone to having the spacer pop out. dick cepeck 2" lift coils can be had for under $70 and are a safe way to go about it. i will get you a link to some when i am on my computer. cause im on my phone right now.
Old Nov 19, 2010 | 08:29 AM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Default coils spacer
I have the spacers from autozone that look like little rubber donuts. If you put them in the middle of the coil like it claims you wont notice much. But if you take the spindlle off and put the spacer on top of the coil and then assemble it all back together you will get a solid 1''. I'm currently doing this now. Had them in for 30,000 miles and haven't had a problem. It was still able to be aligned. It will make your ride a little more stiff but not as stiff as the lift coils. If you want a lot more of a lift you can put the spacers on the top and bottom of the coil and you will notice a big difference. BUT. The ride will be stiff and bouncy and its likely you wont be able to get it aligned without longer upper a frames. I've done every kind of lift on the 2wd blazer so just let me know if you have any questions. The rubber coil spacers are only 9 bucks a peice at autozone, pep boys, and advanced
Old Nov 19, 2010 | 02:58 PM
Thanks for the responses. Ive done a lot of research and decided i'm just going to save my money and get a Zr2. No reason to put money into a 2wd when it will never be a 4wd.
Old Nov 19, 2010 | 02:59 PM
SFA swap your 2wd and add a 4wd transmission & transfer case!
Old Nov 20, 2010 | 07:32 AM
I agree. It would be cheaper to add 4wd if you have the tools and time. Other than that can't go wrong with a zr2!
Old Nov 20, 2010 | 09:33 PM
nismo_2005's Avatar
yeah i had a 2wd with spindles moog 5664 coil springs and shackles in the back on 31's and it still was not what i wanted im way happier with my blazer
blainenbecky
Mar 9, 2013 10:38 PM
Lancealot
Feb 22, 2011 07:34 AM
speterson1011
Lifting Tech
Oct 11, 2009 01:46 PM
rocktheguitarist
Lifting Tech
Aug 26, 2009 09:23 PM
Rp9110
Lifting Tech
17
Feb 14, 2008 08:59 AM
