Why will the rough country lift not work on a 2005 Jimmy 4wd? bad customer service
Old Oct 30, 2010 | 04:30 PM
rob_bellamy's Avatar
rob_bellamy is on a distinguished road
Default Why will the rough country lift not work on a 2005 Jimmy 4wd? bad customer service
Why will this lift not work.. I talked to rough country today and they were very rude..
[Rusty] Can I help you?
[Visitor] Hey! i am wondering why your lifts for blazer and jimmys do not go up to 2005 but stop at 2003
[Rusty] cause that is the last year our kit will work on
[Visitor] but nothing changes the last two years? will this kit work on a 2005?
[Rusty] NO NO
[Visitor] i recomend rough country does their research.. very dissapoint
[Rusty] no you should do more research cause then you would know the suspension is diff from 03 to 05
Is there actually a difference between the those years? .. i rly just want the upper control arms for the better angles and possible get a better suspension lift down the road.....
Old Oct 30, 2010 | 06:18 PM
Dbam31's Avatar
Dbam31 is on a distinguished road
its the same.
seriously just torque your t-bar bolts and buy shackles off ebay your blazer is the same as the models from 1998 to 2004...its all the same.
hope it helps, i bought the rough country lift, and i wish i saved a couple bucks, cuz the lift kit isn't worth it.
Old Oct 30, 2010 | 06:21 PM
69chevelle's Avatar
69chevelle is on a distinguished road
[Rusty] NO NO
according to gmpartsdirect, the upper control arm is the same from 95-2005.
Old Nov 21, 2010 | 05:35 PM
cb6's Avatar
cb6
cb6 is on a distinguished road
Hi Rob, me too I’m looking for this kit for my blazer 2005. I find out the only different parts in suspension are this one:
Torsion bar, s-series, right, blazer/sonoma/s10 - 4wd - 4WD year 04-05
Bushings, blazer, jimmy, w/o chassis pkg. - 4wd - 4WD year 04-05 (For the lower control arm)
Stabilizer bar, blazer, jimmy, w/o high wider pkg. - 4wd - 4WD year 04-05
Lower control arm, s-series, right, w/o high wider pkg, blazer/sonoma/s10 - 4wd - 4WD year 03-05
http://www.trademotion.com/partlocat...layCatalogid=0
Just let me know if you go for it.
jtbwatson
May 26, 2013 02:59 AM
ohsofly
Mar 27, 2013 12:44 PM
brendan127
Dec 10, 2011 01:18 AM
DetailersDomain
Detailing
Oct 6, 2011 08:01 PM
BGwood88
Dec 8, 2008 06:07 PM
