Drop Pitman Arm
maybe someone can answer my question i have a 96 s10 blazer with 3" body and 3" suspension lift how much of a drop pitman arm do i need and where can i find one?
u still dont really need one. i have 11" of lift on mine and running a solid axle and im using my stock pitman arm. gives me clearance when im flexed out. if ur still ifs id leave urs alone and just grease it up if u have play.
or do i even need a drop pitman arm for this?
ok thanks and would it cause my idler arm to wear out faster if i did not change it and will a moog pitman straighten out my steering wheel cause with the stock pitman arm the steering wheel is not centered when going straight
u can check ur idler arm and other steering linkage. if they are all sound and ur wheel still isnt straight u can remove ur wheel and put it on straight. but u prob have sum loose joints. its typical in these rigs.
greatwhite
11-28-2010 11:54 PM
88s10Blazer
12-24-2009 08:43 PM
kornphlake
12-18-2006 02:18 AM
