Drop Pitman Arm
Old 01-24-2012, 09:50 PM
xachman17's Avatar
xachman17 is on a distinguished road
Default Drop Pitman Arm
Where can i find a drop pitman arm for a 2" lift on a ZR2? i have looked everywhere and no luck
Old 01-25-2012, 12:17 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
u can use a xj pitman arm too. same splines.
Old 01-25-2012, 09:03 AM
xachman17's Avatar
thanks man i didnt know that
Old 01-27-2012, 10:36 PM
skotti's Avatar
skotti will become famous soon enough
why do u need a drop pitman for 2" lift? 2" sounds like its still ifs, and in that case use oem replacement.
A drop pitman arm will not work if its stock ifs.
Old 01-28-2012, 12:36 AM
neo71665's Avatar
It will work you just don't need one with an ifs. Prolly only make the idler arm wear out faster than they do now on these trucks.
Old 01-28-2012, 08:31 AM
skotti's Avatar
stock pitman arm has the tie rod end built in. any drop pitman does not.
he would have to make a custom drag link, one end would have to have the tapered hole for idler arm. the other end would need a threaded insert to accept a tie rod end. then even further this drag link would still need to accept oem tie rod ends.
Note even if u did manage to do all this, the new angle would destroy both idler and tie rod end very very quickly.
so yes a drop pitman from a xj will bolt onto our steering box...will it work for ifs...no
Old 01-29-2012, 09:28 AM
xachman17's Avatar
so a oem replacement will tighten my steering back up?
Old 01-29-2012, 09:46 AM
xachman17's Avatar
it is still stock except for the 2" torsion keys i installed
Old 01-29-2012, 03:08 PM
duxtoyz's Avatar
replacing the bushings on ur stock arm or replacing the arm would tighten ur steering up. putting a drop arm on an ifs rig wouldnt benefit u any. just replace urs with a stock oem one and grease it and u should be fine.
Old 01-29-2012, 09:42 PM
xachman17's Avatar
okay, makes sense. thanks alot
Quick Reply: Drop Pitman Arm
