Fitting 31x10.5x15 tires
What all would I need to do in order to fit 31x10.50x15 tires on my truck? Could I just crank the t-bars slightly and get shackles for the rear or would I need to get a suspension/body lift?
Thanks!
Thanks!
wheel spacers effect would depend on the wheels you put them on.
if stock i would think not....but that is just my opinion.
i run camaro wheels and the backspacing is 4.5 vs the stock 6".
so that puts my wheels out 1.5 past stock.
if you search around the forum you may find a more experienced answer.
if u do a key and shackle lift ud clear 31s fine and keep ur flaps. but just cranking ur bars and adding shackles will cause u to have to remove ur flaps. u can buy the zr1 keyways from a gm shop and itl add almost three inches. just putting them in moves ur stock location up and gives u the ability to move up more. i would recommend doing the zr1 keys and a 2" shackle to clear 31s. but a 2" body lift isnt a bad idea either.....theres also a ball joint extention u could use along with a shackle. the spacer helps realign ur camber when u crank ur bars. ud be into this lifting option maybe $100-150 at most.
