front end leveling
Old Mar 9, 2009 | 02:25 PM
dober's Avatar
dober is an unknown quantity at this point
hey wolfpack heres a question? if i crank the t-bars 1.5' how much lift will it give me? i see that you said 2-3".
Old Mar 12, 2009 | 12:25 AM
bandidolenny's Avatar
If you crank the bars 1.5" then you will raise the front end 1.5". In order to go higher you gotta go to the indexed keys that come with a suspension lift.
Old Mar 12, 2009 | 08:48 AM
And even with indexed keys, you will be flexing your CV shafts beyond what they were made to flex. +2" and you will break things more often even if you are just driving around town.
Old Mar 12, 2009 | 09:23 AM
willjones's Avatar
Wolfpack if you have 2" shackles, then you need to change your sig. I dont appreciate being lied to.
Old Mar 19, 2009 | 10:08 PM
minorthreat412's Avatar
minorthreat412 is on a distinguished road
I installed one of those cheap 2" lifts that you can buy off of ebay for about $150. I honestly would advise not to do that.
The kit came with shackles for the rear leaf springs and tbar keys for the front.
After installing everything and driving it, I realize that something is grinding. I look and find that my axle boot on the passenger side came undone because of the excess angle that the lift had put on the cv joint (as talked about earlier). I then relaxed the tbars all the way and drove it again. The grinding was gone until i went over 70 mph or went over bumps on the express way. I replaced the axle and the problem is slightly better, but it's still there.
So, my question is, do ZR2 blazers have different axles than LS blazers?
My second question is, where can I find an axle that'll handle the 2 in lift?
--Thank you, Chad.
T...K21
May 25, 2013 10:26 AM
muntyv
Lifting Tech
Aug 13, 2012 12:45 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
NYBLAZER
May 10, 2010 01:22 AM
Rp9110
Jan 5, 2008 11:27 PM
