good lift
Old Oct 1, 2007 | 06:58 PM
coplinb's Avatar
coplinb is an unknown quantity at this point
Default good lift
i know im horrible about looking through previous posts, but i cant seem to find an answer to my specifics. i have a stock 01 2dr 4wd and was wondering what kind of options i have for an inexpensive, not to crazy lift that wouldnt be TOO hard to accomplish. i just really want to run normal size all terrians for average hunting, fishing trips where i can go most places and not get stuck. thanks for any info or pics
Old Oct 1, 2007 | 07:19 PM
Default RE: good lift
Well, unless you go for a full on suspension lift, your only options for added ground clearance are a mild t-bar crank and rear lift shackles. The only true suspension lift that is made is a 6" lift and that is $$$.
To take full advantage of a t-bar crank, you really should step up to atleast 30" tires. I was able to go a ton of places with my 28" tires on my old Bravada at stock height. Heck, I've already been creek crossing with my Rainier a few weekends ago and that is stock right now as well. But it also has larger tires and more ground clearance than my old Bravada.
Old Oct 1, 2007 | 07:59 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
I would say either do a 2" bodylift and get 31" tires, would give you an inch of extra frame clearance with just the tires and 3" of body height. or you could do a combination of 1" tbar crank 1.5" shackles and a 2" bodylift and then get 32" tires which would give you and inch and a half of frame height from the tires and 1-1.5" of fram lift from the tbar and shackle lift and 2" from the bodylift for a total of 2.5-3" of frame lift and 4.5-5" of body height. Just some things to think of. Of course with cranking you torision bars you increase the risk of frontend suspenison component wear (ie. ball joints, CV joints, and bushings)
Old Oct 1, 2007 | 08:40 PM
99 Blazer 4x4's Avatar
99 Blazer 4x4 is an unknown quantity at this point
Ok coplinb, I looked this up the other night ( I figure since I am going to be starting my projected I needed to be more active with look parts for truck up. Heres a link open to the right section ( its rocky mountain suspension they have a 2, 5 and a 6" lift with prices and decent description and if you go to the top section of the page you can click on the section called photo gallery and there are quite a few blazers like your with lifts and description. Heres the link:
http://www.rockymountainsusp.com/GM_S10_4wd.htm
Here is another site with parts for your truck withparts for your truck. I even searched for your 2001 now click on the blue menu bar under truck parts and pull up stuff for your truck.
http://www.4wheelparts.com/
Hope this gives you an idea.
sam31183
May 3, 2012 05:31 PM
Rselarep
Dec 11, 2011 07:14 AM
theclothedcreature
Tires and Wheels
24
May 20, 2010 07:07 PM
99s10blazer
Jun 1, 2007 09:13 AM
lukewb
14
Dec 2, 2006 02:23 AM
