how much lift needed
Old Mar 10, 2010 | 05:49 PM
malcolm88's Avatar
malcolm88 is on a distinguished road
Default how much lift needed
I have a 1998 Blazer 4dr. would like to know how much lift is needed to run 31x10.50x15 hopefully on 8" wheel
Old Mar 10, 2010 | 07:26 PM
Sisk's Avatar
Been discussed MANY times...daily actually.
Do you have a 4x4 or 2wd? If you have a 4x4 do a 2" shackle and tbar lift for ~$60 and you'll be good. If not you'll need coil spacers or a body lift. 2" should be enough lift to clear the tires though. You might have minor rubbing at full lock with an 8" wide rim.
Do a search if you want more info. It's probably THE most asked question here....theres plenty of info on it if you just read.
Tenagator
Jan 22, 2014 06:04 PM
Blade_24k
Oct 25, 2013 04:26 AM
Doctorvette
Nov 5, 2012 11:57 PM
dsapsfo1
Jan 22, 2006 03:59 PM
