Installing Torsion Keys
Old Jan 19, 2012 | 08:20 PM
blazinhigh98's Avatar
blazinhigh98 is on a distinguished road
Default Installing Torsion Keys
I just got a 1-3 inch torsion key set. i was wondering about removal. i know how to take the old keys out and install the new ones. but my question is would a 1 ton gear puller suffice to hold the key while i remove the adjusting bolt and block. if i remove all the weight off the torsion bars (aka jack the front end off the ground)
Old Jan 20, 2012 | 06:58 PM
c_mcintosh's Avatar
c_mcintosh is on a distinguished road
i installed that kit as well. i made a make shift puller to get it out and it surficed (puller with threaded metal). to install tho the weight and pressure with the new keys were too much. so i went out and bought the proper key removing and installing tool which was i think 150 but i got it for 50$. that tool really helped and made putting the new keys in a lot less scary!!! hahaha once u push the keys up enough to pull out the little movable suport and bolt u can slowly remove the pressure and the tool. then u must pull back the cross member that goes to the other side back a bit to pull the key off the torsion bar. then its the same to put the new keys on. hoped this helps
papacope
Jan 28, 2010 06:21 PM
lovemy01ZR2
Lifting Tech
Oct 9, 2009 09:20 AM
95_4door
Lifting Tech
Apr 13, 2008 01:05 PM
tkebillybob
Jan 16, 2008 06:45 PM
sasquatchfound
Suspension Tech
22
Jul 19, 2007 12:28 AM
