just thinking 2wd lift...
Old Jul 26, 2007 | 10:40 PM
ryan's Avatar
ryan is an unknown quantity at this point
Default just thinking 2wd lift...
ok guys and gals, so i've been thinking of lifting my 00 2wd 2dr and seems to be like no one makes a nice kit or a spindle lift. now i would like a suspension lift to accommodate some 17's and some 285's. ok if the 96-97 models have lift kits available can i swap myfront suspension for a suspension from the 94-98 models?
If this can be done and if everything worked what would i be losing? and what i mean is why did chevrolet change the brake system and front suspension set up?
Old Jul 27, 2007 | 09:12 AM
sky96744's Avatar
sky96744 is an unknown quantity at this point
Default RE: just thinking 2wd lift...
Are you talking about the ZR2 model? I dont think a ZR2 susp would work on a non ZR2. Im no expert but thats just what I read. Do a search. How much lift are you wanting? Whats the budget?
Old Jul 27, 2007 | 10:50 AM
ryan's Avatar
will the 94-98 2wd blazer front suspension fit the 00 2wd blazer like the spindles fit the control arms with older brakes or would i have to change out the to the older control arms and all?
Old Jul 27, 2007 | 01:16 PM
sky96744's Avatar
I dont know. Wait until the guru's get on they will be able to answer that.
[sm=sorry.gif]
Old Sep 17, 2007 | 07:20 PM
ryan's Avatar
ok lately I have been talking and reading on the s10forum.com and it looks like the 98+ up blazers control arms is the same as the 94-97's. what would have ot be done is if I went with a lift spindle from a 94-97 then i would need the brakes, caliper,plate and all, should work fine. now is deciding if i would want to spend the money to do it..........
Old Sep 19, 2007 | 11:16 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
If you are just wanting a couple of inches to clear the bigger rims, why not a body lift??
Old Sep 22, 2007 | 09:47 PM
ryan's Avatar
nope no body, and no big wheels. i want a clean offroad look. i would like some narrow 33's with the front a tad higher than the back with some black 15's i think. It will probably never see anything other than paved roads and armorall...maybe the boat ramp also. ohh and a off-road rack on top.
kontrix
Lowering Tech
Nov 8, 2012 01:12 PM
1994BlazerS10
Nov 29, 2009 07:22 AM
97ssblazer
Feb 16, 2009 10:10 PM
95_4door
Jul 2, 2008 07:34 PM
schums
Lifting Tech
Sep 21, 2007 07:58 PM
