To lift, or not to lift
Old 08-12-2011 | 05:57 PM
98chevyblazer's Avatar
98chevyblazer is on a distinguished road
Default To lift, or not to lift
Hey guys, recently I've been debating whether or not to do the shackles and t-bar lift to my Blazer. I drive around 13,000 or so road miles a year, and I plan to offroad about 4-5 weekends a year, give or take. I know it wears on the front end parts, so I was just wondering if anyone has some input as to whether or not I should lift with as much regular road driving i'll do. It sits at 282k right now, and I know I need new shocks and tires (soon) all around. Any input will be greatly appreciated.
Thanks,
Andrew
Old 08-12-2011 | 07:12 PM
warthogdriver's Avatar
well i drive almost as much as you road wise and i did that lift and more.
i dont seem to have anything out of the ordinary go wrong on mine.
only thing i had happen was the boot slipped off both cv shafts...it was an easy 3.00 fix though...only problem and it has been just about 2 years since i started lifting.
my only advice i guess would be get good parts when you do replace them, i went with moog. you will pay more then the autozone/advanced price, but you will get a part that will hold up.
just dont beat on your ride and you will be fine i think.
i have just over 230k on mine...so i guess i have done almost 30k with that same setup and more.
only problem i see money wise is you may like the lift and want more...seems to happen around here
Old 08-12-2011 | 09:32 PM
Haha probably, but it's all i can do for now. So it sounds like I'll be okay doing it, and I was looking on Summit and they suggested some ProComp shocks which seem like they're a good quality brand. What did you use to crank the t-bars? I saw that there is a part on ebay you can buy for like $45 but im not sure if there's a cheaper way ro somethin.
Old 08-12-2011 | 10:03 PM
if you search the diy section there is a how to....it is totally free!!!
you need only a wrench and a measuring tape, and a jack.
piece of cake.
the shackles...also a how to if you search...is a bit of a pain.
if you keep the torsion bar crank at 1.5" more than what you have now (assuming stock) you will be fine. that seems to be the limit on the lift before you cause damage.
from what i understand the lift causes the cv joints to operate at a steeper angle that can cause the excessive wear.
you should only need to buy the rear shackles...rear leaf bushings and some anti-seize for the bolts (anti-seize is personal pref.)
Old 08-12-2011 | 11:04 PM
I'll check it out, thanks for all the help
Old 08-13-2011 | 12:37 AM
AJBert's Avatar
AJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the rough
There is really only one reason to do any kind of lift and that is to fit bigger tires. The want/need for bigger tires is for greater ground clearance.
If you aren't planning on getting bigger tires there is no need to lift.
Old 08-13-2011 | 10:52 AM
Yeah I'm gonna run 31's after i do the lift since I'm gonna need new tires soon anyways.
AGodlyCanuck
Lifting Tech
16
04-22-2014 05:53 AM
Chadoo951
13
06-30-2010 02:59 PM
sandman1412
Lifting Tech
05-09-2010 09:57 PM
wayland
12-09-2009 01:38 PM
Thor_449
05-26-2008 01:00 PM
Quick Reply: To lift, or not to lift
