lifting
Old Feb 15, 2009 | 11:53 PM
lene 98's Avatar
lene 98 is an unknown quantity at this point
Default lifting
how do you crank up the factory t bar
Old Feb 15, 2009 | 11:55 PM
WolfPack's Avatar
Default RE: lifting
Under the vehicle, about where the front seats are, you'll see a crossmember with two long bars running out of it up to the front wheels. Those torsion bars go into the cross bar, and just inside of the bars is a bolt. Give the bolt a crank. 1/4 turn of the bolt head = .2-.25' of lift.
Also if you search a bit, theres a few tutorials/how-tos/DIYs on tbar cranking.
Old Feb 16, 2009 | 12:00 AM
lene 98's Avatar
Default RE: lifting
that helps
Old Feb 16, 2009 | 06:48 AM
SockJock's Avatar
SockJock is an unknown quantity at this point
Default RE: lifting
Be sure to raise the front of the vehicle off the ground first to take the pressure off the tbars. Then crank your adjuster bolts.
Old Feb 16, 2009 | 07:51 AM
WolfPack's Avatar
Default RE: lifting
ahhhh yea haha thats a crucial step!
Old Feb 16, 2009 | 04:43 PM
bblackz28's Avatar
bblackz28 is an unknown quantity at this point
Default RE: lifting
lift the front all the way up or just enough to load the suspension?
Old Feb 16, 2009 | 09:15 PM
WolfPack's Avatar
Default RE: lifting
Put the jack on the front crossmember right between the front wheels (er...just behind the axle...that general area). That will lift both wheels off quite nicely. Do the crank, lower the truck, drive around the block to work the suspension out, then park it and measure. Repeat as needed.
You dont have to lift the front up...but it just makes adjusting the bars much easier. Ive heard of the adjuster bolts snapping though from trying to do it under load..
Old Feb 16, 2009 | 09:41 PM
bandidolenny's Avatar
Default RE: lifting
My trick is to over do it and then you can lower as needed as you drive around.
mhollis
Tires and Wheels
Jul 26, 2009 08:41 AM
vtblazer
Lifting Tech
Oct 19, 2008 11:09 PM
bluesjam99
Feb 18, 2007 08:24 PM
eslhockey92g
Suspension Tech
Jun 22, 2006 11:29 PM
casualvic
Suspension Tech
Jun 22, 2006 12:15 AM
