lifting
Old Nov 30, 2012 | 02:04 PM
bayer654's Avatar
bayer654 is on a distinguished road
Default lifting
i have a 2000 chevy blazer lt and just put 33in tires on the back with a stock lift. they rub a little bit on the inside bc of the *****. im trying to figure out how to get about 3in of lift for the front and the rear so i can clear the rear tires and put some in the front. this is my dd and im trying to get it done fast and right but do it myself at the sametime.
Old Nov 30, 2012 | 02:20 PM
newguy's Avatar
2 inch shackles or add a leaf for the back, t bar crank 1 1/2 inches in the front. Then a 2inch body lift. should be able to it for under 300.00
Old Nov 30, 2012 | 07:17 PM
duxtoyz's Avatar
duxtoyz is on a distinguished road
2 " shackles, zr2 keyways for trosion bars with a lil tbar crank, not so much cranking needed with the new key ways, and 2" body lift will work. and still under $300.
Old Nov 30, 2012 | 11:25 PM
blaz's Avatar
blaz is on a distinguished road
I am currently running 33x10.5x15's on Z28 rims. In order to make them fit with only minor rubbing I have done the following.
Lift shackles 6" hole to hole.
2 thin long add a leaves per side.
2.5 " rough country lift on the front only.
Significant trimming on the rear of the front fenders and rear of the rear bumper covers.
2" PA body lift.
You could get away with out the front 2.5" lift but you would have to crank your T bars quite a bit.
Good Luck.
mhollis
Tires and Wheels
Jul 26, 2009 08:41 AM
vtblazer
Lifting Tech
Oct 19, 2008 11:09 PM
bluesjam99
Feb 18, 2007 08:24 PM
eslhockey92g
Suspension Tech
Jun 22, 2006 11:29 PM
casualvic
Suspension Tech
Jun 22, 2006 12:15 AM
